stainless one that has worked very well. My site is down at the moment, and
I'm a long way from home, so I can't look up the source, but will let you
know where I got it when I can.
Ron
On Sun, Feb 12, 2012 at 1:48 PM, Roland Kriening <kriening@rogers.com>wrote:
Thanks Mike,
Looks like my original message did not make it onto the list. I have
reposted it here to see if there are any additional comments from other
builders.
Three questions....
1. Any trick to improving the way the seat pins drop down into the seat
tracks? Even with careful alignment when installing the seat tracks, it
seems impossible to get perfect alignment of the pin into the seat track
holes.
2. There is a tiny pin that goes through the seat pin which holds the
spring
in place. Seems logical that constant vibration will cause the pin to move
and possibly come out. Any experience or fixes for this. Bend the sides of
the pin so it cannot slide out???
3. Some builders have installed forged eye rings (bolts) into one of the
holes at the top of the strut to use as tie down points. I have been
searching for one that will fit the 1/4" holes, but without much luck. Can
someone provide me with a source?
Roland
R56
