Result of new message to murphy-rebel [2/28/2001 18:11:05]
Legeorgen
Post by Legeorgen » Fri Feb 17, 2012 8:47 pm
In a message dated 2/28/01 7:16:18 PM Pacific Standard Time,
list-server@dcsol.com writes:
I just weighed my Mark Landoll vibration dampener and it was 10 lb.. I
picked
it up with the engine purchase (second hand) and had second thoughts about
using it because of the extra weight up front. I'll be reconsidering it
now.
WD was my choice for blades. WD does guarantee their blades, don't they?
Some of you have 72" and some 70'' blades. What would be the advantage or
disadvantage to either, that could not be changed with pitch to adjust the
desired RPM?
Bruce G
------ Start of attached email. Subject: Result of new message to murphy-rebel [2/28/2001 18:11:05] ------
Not a member of murphy-rebel
--- Original Message ---
Received: from imo-m04.mx.aol.com ([64.12.136.7])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 414331937; Wed, 28 Feb 2001 18:10:53 -0900
Received: from Legeorgen@cs.com
by imo-m04.mx.aol.com (mail_out_v29.5.) id b.a0.10b716bc (26123)
for <murphy-rebel@dcsol.com>; Wed, 28 Feb 2001 22:10:44 -0500 (EST)
Message-ID: <a0.10b716bc.27cf17b4@cs.com>
Date: Wed, 28 Feb 2001 22:10:44 EST
Subject: Re: Prop' Balancer
MIME-Version: 1.0
Content-Type: text/plain; charset="US-ASCII"
X-Mailer: CompuServe 2000 32-bit sub 113
I just weighed my Mark Landoll vibration dampener and it was 10 lb.. I picked
using it because of the extra weight up front. I'll be reconsidering it now.
desired RPM?
Bruce G
------ End of attached email ------
