[rebel-builders] Water in tanks when flying in rain
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:37 pm
Exactly Bob. All they are is a nice place for a water puddle, or snow to sit
and melt, and drip.. drip.. drip thru any hint of a worn O-ring. Useless to
grab when you're slipping off the float step fueling as well..... ;O)
Sent: Tuesday, January 31, 2012 7:05 PM
Subject: Re: (SPAM?) Re: [rebel-builders] Fuel ports into cabin
Hi Paul !
I have seen lots - if you have the flush caps !!
Absolutely none with the regular necks and caps....
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
and do not necessarily reflect the views of any other entities or
persons.
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
On Tuesday 31 January 2012 18:42:51 Paul Lennemann wrote:
Does water enter the fuel tanks when flying in the rain?
Paul Lennemann
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:37 pm
A closeup of my snorkel tubes is at http://n254mr.com/node/746 I cut the
short, larger diameter outer end tube at a slant leaning forward (going up)
which keeps the rain out on the ground. Others have rotated that outer end
piece 180 deg. so the slant leans the other way, which also keep water out
on the ground, and probably provides better ram air pressure in flight.
I've never had water in the tanks, even through heavy rain on the ground,
and moderate in flight.
Notice that either way, the main, smaller diameter tube has a squared off
end inside the larger diameter but shorter end piece. That means that even
if you have horizontal wind, the raindrops still have to climb up and over
that edge, or lip, inside too. :-)
Ron
