Marine fuel caps
Marine fuel caps
Post by Ralph Baker » Fri Feb 17, 2012 8:47 pm
We got the marine caps with Elite 61E. It seemed a nice touch as we did
opt for the float attach fittings. However, there is was a safety issue
with the ones we received. The cap would bottom the screw threads in the
neck before the "O" ring would seal. In other words , it was impossible to
get a fuel / air tight seal. If a pressure check of the tank was made by
sealing the opening without the cap this would siphon fuel in flight and/or
allow water in. Murphy was made aware of this by email but did not reply.
We are using the flush caps as used on the Van's aircraft, which are
available from Aircraft Spruce. These use a flip top cap which cams over
center and expands an "O" ring to seal.
If you elect to use the marine caps be sure they do, in fact, seal.
As a related issue, Don Smith at Seal Pak tells me the adhesion promoter is
not needed when painting the brushable Pro Seal over a new layer of the
standard Pro Seal.
From: murphy-rebel-d Digest <murphy-rebel-d@dcsol.com>
To: murphy-rebel-d@dcsol.com
Subject: DIGEST - murphy-rebel-d
Date: Wednesday, February 28, 2001 2:58 PM
From: APAT@ISTAR.CA Subject RE: Wow - PS 890 A-2 is
the way to seal your tanks!
From: APAT@ISTAR.CA Subject Re: Fw: wing tip wiring
From: LISAFLY99@AOL.COM Subject Re: Composite tailspring
From: WRAYT@SYMPATICO.CA Subject Re: Composite tailspring
From: APAT@ISTAR.CA Subject Re: Composite tailspring
To: MURPHY-REBEL
Subject: RE: Wow - PS 890 A-2 is the way to seal your tanks!
Date: Wed, 28 Feb 2001 08:48:21 -0900
Received: from smtp.interlog.com ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 380573765; Wed, 28 Feb 2001 08:48:15 -0900
Received: (qmail 21993 invoked from network); 28 Feb 2001 17:48:09 -0000
Received: from unknown (HELO ip135.toronto81.dialup.canada.psi.net)
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 17:48:09 -0000
Mime-Version: 1.0
Hi Mike !
Ahhhh ! These ARE the same caps I have on Rebel #001 !! We
use a Twonie to open them ...
There should be a rubber "O" ring around the top of the caps -
and it does seal pretty well. I have had a problem with water getting
in only over the winter, and I do leave the caps a bit loose, because
the rubber ring tends to expand a bit, and dry out, so it can be a
real bear to open the caps. Perhaps there's a lube you could put on
the "O" ring to allow tightening completely.
As I mentioned, ours have had holes drilled beside the cap,
through the rubbery plastic support, into the tank. These are fitted
with inverted "J" tubes for venting (and these ARE very important !)
I guess you'd have to use maybe 1/4" or 5/16" tubing to be sure of
getting enough air flow. (ours are only 1/16" ID - enough for the
912 ...) The alternative would be to run inverted "J" tubes up
from the top of the sight guages, through the wing root fairings
on both sides - might be easier.
I wouldn't worry too much about the water leaking, as long
as the "O" rings are in good shape, AND - you ALWAYS check drain your
tanks before flying anyway ! (Also - fifteen minutes or so after
refuelling. I've had water pumped in from several airport tanks !)
I know of several different aircraft here with flush caps
where the owners put inverted plastic butter containers over the
fuel fillers, and secure them with small bungee cords or just
electrical tape, to keep water out. This can be a problem with
all flush caps, although I never had any water problems with the
flush caps on the Super Rebel. These are a higher quality metal
cap with a quarter-turn locking mechanism to seal against the
"O" ring.
-------------------------------------orig.---------------------------------
At 10:10 AM 2/24/01 -0900, you wrote:
My caps are made for boats (says "Marine" on the package they came in).
They screw in and once they are in they are flush with the recepticle
which
only sticks up about a 1/4 inch. The cap has no handle or tab.
Instead,
there is a slot which requires something like a quarter to open/close.
The
Renegade Spirit I used to own had a similar cap and I just cut a small
piece
of aluminum to fit in the slot, then drilled a hole in it so I could
hang it
on my key chain.
After reading Wayne's comments on this topic, I am dismayed. He is
quite
right. If the cap leaks air going out around the threads, it will also
leak
water going in. What am I to do? Is it possible to retrofit a better
cap
in the wing I have already finished without having to open up the tank?
If
not, I guess I'll build a little house over the cap to keep the water
out.
Maybe set up a little garden, white picket fence,... Anything but open
up
that fuel tank! Perhaps I can figure out some way to add an o-ring
seal.
APAT@ISTAR.CA
Sent: Friday, February 23, 2001 3:29 PM
with SMTP id 232350828; Fri, 23 Feb 2001 15:29:01 -0900
Received: (qmail 25684 invoked from network); 24 Feb 2001 00:28:56 -0000
Received: from unknown (HELO ip97.toronto99.dialup.canada.psi.net)
(154.20.93.97)
by bretweir.total.net with SMTP; 24 Feb 2001 00:28:56 -0000
Mime-Version: 1.0
Hi Mike !
Not sure about the caps you have - ours are just a spin-on cap
like a car gas cap - tabs on the bottom to grab onto slots on the top of
the filler neck, which sticks up about an inch above the wing. Are yours
different ?
A tee off the top of the guages is a "Good Thing"(tm) - it
might be easier to have it poke up through the wing root fairing on
each side. Just to make it easier to get at, and to avoid fuel dribbling
down into the cockpit ...
I was just wondering if ANYONE can tell us what the latest
Super Rebel manuals say about venting.... ????
....bobp
At 11:56 AM 2/23/01 -0900, you wrote:
I'll have to look at the caps again. I don't remember seeing vent
holes in
the cap. I also don't remember finding a leak in the cap itself (i.e.,
where a vent hole would be if there was one). The leak I found was
around
the cap threads. I guess that's a form of venting. I haven't run
across
mention of venting the tanks in the manual anywhere, but I haven't read
whole manual yet. I was sort of planning on venting the tanks with a
tee
at
the top of the sight tube, vented cap or no vented cap.
-------------------------------orig.------------------------------------
To: <MURPHY-REBEL@dcsol.com>
Hi Mike !
I'm not sure I'd want to trust Pro-Seal that had been thinned
with MEK - might change the flex properties over the long term ....
If your caps are the same as the standard ones for the Rebel,
they're SUPPOSED to be vented. I've always run a 1/16" drill through
the vent holes anyway, just to be sure. Is there another vent on
the Super somewhere ??
....bobp
At 06:05 PM 2/22/01 -0900, you wrote:
local
that
they
tank
in
rivet
supplied
My
looked
tank
brushing
in
To: MURPHY-REBEL
Subject: Re: To Bob Patterson
Date: Wed, 28 Feb 2001 08:54:06 -0900
with SMTP id 380917781; Wed, 28 Feb 2001 08:53:59 -0900
Received: (qmail 22701 invoked from network); 28 Feb 2001 17:53:57 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 17:53:57 -0000
Mime-Version: 1.0
Hi Rick !
Sorry - my ISP has REALLY screwed up my email !! The old address
has been erratic for over 3 weeks, and they keep telling me it'll be OK
in a couple of days !!
In the mean time, they've given me a couple of new ones to use,
and one seems to be OK - for now, you can reach me at:
apat@istar.ca
At 08:07 AM 2/27/01 +1100, you wrote:
Bob !
I tried to send you an e-mail last night ...and it came back as
"undeliverable" !?!?
Do you have a new e-mail address ?
Rick & Wendy Harper
Rick & Wendy Harper
16 Tor rd, Dee Why,
N.S.W. 2099
Australia
rjwh@ozemail.com.au
rjwh56@hotmail.com
Ph : 02 9971 7889
Mbl : 0416 041 007
O'seas Ph : 612 9971 7889
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2314.1000" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV><FONT size=2><EM>Bob !</EM></FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2><EM>I tried to send you an e-mail last night ...and it
came
back as "undeliverable" !?!?</EM></FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2><EM>Do you have a new e-mail address
?</EM></FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2><EM>Rick & Wendy Harper</EM></FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><EM><FONT size=2>Rick & Wendy Harper<BR>16 Tor rd, Dee Why,
<BR>N.S.W.
2099<BR>Australia<BR><A
href="mailto:rjwh@ozemail.com.au">rjwh@ozemail.com.au</A><BR><A
href="mailto:rjwh56@hotmail.com">rjwh56@hotmail.com</A><BR>Ph : 02 9971
7889
<BR>Mbl : 0416 041 007<BR>O'seas Ph : 612 9971
7889<BR></FONT></EM></DIV></BODY></HTML>
To: MURPHY-REBEL
Subject: Re: Fw: wing tip wiring
Date: Wed, 28 Feb 2001 09:02:57 -0900
with SMTP id 381449421; Wed, 28 Feb 2001 09:02:51 -0900
Received: (qmail 23891 invoked from network); 28 Feb 2001 18:02:48 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 18:02:48 -0000
Mime-Version: 1.0
Hi Rebel 505 !
Many builders now run tubes through the wing, so that the wires
can be easily replaced if they should deteriorate years later. It also
makes it easy to add new wires later, if you add strobes, etc. Many
production aircraft use grommets & tie-wraps, forcing the owner to
have the wing opened just to replace wires ! Some early builders
used rigid PVC tube, but lately, many have found the clear flex
tubing much easier to install. The plastic is considered safer
than aluminum, because the wires are less likely to rub through
and short out on it.
You are absolutely going the right way, by running your wires
down inside the strut, along with the pitot tubing. This makes everything
MUCH easier and tidier to connect to the panel !
Just suggestions ........ ;-)
--------------------------------orig.-----------------------------------
At , you wrote:
At 10:05 PM 2/26/01 -0700, you wrote:
To: murphy-rebel@dcsol.com.Sales.Department
Sent: Monday, February 26, 2001 10:01 PM
Subject: wing tip wirring
Hello from Calgary
I drilled holes in the tip ribs and installed rubber grommets to pull
my
wires for wing tip lights through. Is this looking for trouble. Should I
run
aluminum tube or plastic hose to feed my wire through. The wire will run
down the strut, not straight through to the fuselodge.
All comments will be appreciated,
REBEL 505
<HTML><HEAD>
<META content="MSHTML 5.00.2919.6307" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV>&nbsp;</DIV>
<DIV style="FONT: 10pt arial">----- Original Message -----
<DIV style="BACKGROUND: #e4e4e4; font-color: black"><B>From:</B> <A
href="mailto:carol51@attcanada.ca"
title=carol51@attcanada.ca>carol51</A>
</DIV>
<DIV><B>To:</B> <A
href="mailto:murphy-rebel@dcsol.com.Sales.Department"
.Department</A>
</DIV>
<DIV><B>Sent:</B> Monday, February 26, 2001 10:01 PM</DIV>
<DIV><B>Subject:</B> wing tip wirring</DIV></DIV>
<DIV><BR></DIV>
<DIV><FONT size=2>Hello from Calgary</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>I drilled holes in the tip ribs and installed rubber
grommets
to pull my wires for wing tip lights through. Is this looking for
trouble.
Should I run aluminum tube or plastic hose to feed my wire through. The
wire
will run down the strut, not straight through to the
fuselodge.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>All comments will be appreciated,</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>REBEL 505</FONT></DIV></BODY></HTML>
To: MURPHY-REBEL
Subject: Re: Fuel tank
Date: Wed, 28 Feb 2001 09:13:59 -0900
with SMTP id 382110453; Wed, 28 Feb 2001 09:13:52 -0900
Received: (qmail 25400 invoked from network); 28 Feb 2001 18:13:49 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 18:13:49 -0000
Mime-Version: 1.0
Well - - I'm still having problems with my stupid ISP, and
CAN'T connect with LINUX <AT ALL> !!! So I've fallen back to
an old box with WinDoze 3.11, and Netscape 3.0 - works well on
many sites (at least, the thoughtful ones).
I can get onto the new dcsol site, and read archives, etc.,
but I DO get scattered .jpg icons over the text in places, and other
little anomalies. Part of this is because I run with Java and JavaScript
turned OFF - I really don't need flash & dazzle, OR viruses !!
Just a real old stick in the mud, I guess - still like plain
text interfaces. (Still do lots of work in FoxPro (NOT <visual>) !!)
Sorry - still haven't completely chilled ! Get tired of
fighting the M$ machine - but their days are numbered .... I think
even Bill G. realizes it's all downhill from here !! Thank goodness !!
At 11:01 PM 2/27/01 -0900, you wrote:
Gosh Bob... even Netscape on Linux will view these pages. That is if
you're
at least running a version that's newer than that Lycosaurus technology
you're flying behind!
Sorry, but figured you've had a few days to cool off, so it should be
safe
to pick on you a little.
By the way, I hope you noticed that the new archive site still supports
dinosaurs like you, while also offering truly usable features to those
who
are even close to keeping up with the times. :-)
Sent: Saturday, February 24, 2001 6:42 AM
Thanks Roger, but THIS is one of those stupid, arrogant web sites
that
won't even let you see the pages unless you have the "latest &
greatest"
web browser !!
I don't understand people who want the public to visit their
sites, then make it impossible !! Usually, they are Micro$oft
victims,
who are so brainwashed they think M$ is the only O/S and browser mfg.
in the world !!
Sorry for the tirade - I've just had a day full of these idiots
----------------------------orig.-----------------------------------------
At 02:41 AM 2/24/01 GMT, you wrote:
clips
following
D_Community=N
(EST)
cutouts
past the
fit
by
To: MURPHY-REBEL
Subject: Composite tailspring
Date: Wed, 28 Feb 2001 09:25:59 -0900
with SMTP id 382830906; Wed, 28 Feb 2001 09:25:52 -0900
Received: (qmail 26800 invoked from network); 28 Feb 2001 18:25:50 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 18:25:50 -0000
Mime-Version: 1.0
Help !!
Is there anyone in Southern Ontario who has a composite
tailspring who'd like to trade me for a metal one ??? We had a
really heavy wind storm here last week, and the composite spring
on my Rebel was sheared off right behind the tail strut supports.
This was one of the middle batch of springs, and was VERY
poor quality - mostly epoxy, with little glass, 'way too thick
in the middle, etc., but I made it fit. I'd still prefer to use
a composite spring on this Rebel, as it's a very light 912-powered
version, and the metal spring just wouldn't bend AT ALL on it !!
Hope someone has one of these composite springs, so I can
get the Rebel up out of the grass quickly !
Thanks !!
To: MURPHY-REBEL
Subject: Re: Composite tailspring
Date: Wed, 28 Feb 2001 09:32:42 -0900
--part1_29.111996b4.27ce9e4a_boundary
Content-Type: text/plain; charset="US-ASCII"
In a message dated 2/28/01 12:26:51 PM Central Standard Time,
APAT@ISTAR.CA
writes:
Thanks !!
BOB
I have a composit spring I was going to replace with a metal one. I'd
have to
pull it off of N414D and work out shipping I live in the states. Got to
run
to the dentist but will check E-mail as soon as I get back for response.
Phil&Lisa Smith #460 N414D
Content-Type: text/html; charset="US-ASCII"
<HTML><FONT FACE=arial,helvetica><FONT SIZE=2>In a message dated 2/28/01
12:26:51 PM Central Standard Time, APAT@ISTAR.CA
<BR>writes:
<BR>
<BR>
<BR><BLOCKQUOTE TYPE=CITE style="BORDER-LEFT: #0000ff 2px solid;
MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px">
<BR>
<BR> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Hope someone has one of
<BR>get the Rebel up out of the grass quickly !
<BR>
<BR>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs
p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n
bsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
bsp;&nbsp;&nbsp;&nbsp;&nbsp;Thanks !!
<BR>
<BR>
....bobp
<BR>
<BR></BLOCKQUOTE>
<BR>
<BR>BOB
<BR>I have a composit spring I was going to replace with a metal one. I'd
have to
<BR>pull it off of N414D and work out shipping I live in the states. Got
to run
<BR>to the dentist but will check E-mail as soon as I get back for
response.
<BR>Phil&Lisa Smith #460 &nbsp;N414D</FONT></HTML>
--part1_29.111996b4.27ce9e4a_boundary--
To: MURPHY-REBEL
Date: Wed, 28 Feb 2001 12:47:05 -0900
Bob give me a call. I think I have what you want. Willing to horse trade.
...Wray
Help !!
Thanks !!
Wray Thompson ...Rebel 306 ...home page http://wrayt.tripod.com/
My ICQ number is 29764664
To: MURPHY-REBEL
Date: Wed, 28 Feb 2001 10:11:36 -0900
with SMTP id 385568406; Wed, 28 Feb 2001 10:11:30 -0900
Received: (qmail 2831 invoked from network); 28 Feb 2001 19:11:26 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 19:11:26 -0000
Mime-Version: 1.0
Thanks Phil ! It looks like there are a few nearby, so we
don't have to wrestle with customs, etc..... Appreciate the offer,
though !
I really LIKE the composite springs, so, unless you're having
problems, I wouldn't rush to change it. They seem to be a bit kinder
to the tailsection ... ;-)
APAT@ISTAR.CA
writes:
Thanks !!
BOB
have to
run
2/28/01
<BR>writes:
<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
<BR>
;.....bobp
<BR>
<BR></BLOCKQUOTE>
<BR>
<BR>BOB
I'd
have to
run
response.
To: MURPHY-REBEL
Date: Wed, 28 Feb 2001 10:12:26 -0900
with SMTP id 385617968; Wed, 28 Feb 2001 10:12:19 -0900
Received: (qmail 2945 invoked from network); 28 Feb 2001 19:12:17 -0000
(154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 19:12:17 -0000
Mime-Version: 1.0
Thanks Wray ! Will give you a call a bit later .....
trade.
...Wray
Help !!
Thanks !!
To: MURPHY-REBEL
Date: Wed, 28 Feb 2001 10:57:41 -0900
--part1_39.11410427.27ceb235_boundary
In a message dated 2/28/01 1:13:01 PM Central Standard Time,
APAT@ISTAR.CA
writes:
BOB
Thats my thought also, thats the reason it's still on there. But I do
have a
metal spring on hand to do a change out. You were a good excuse to get it
done.
1:13:01 PM Central Standard Time, APAT@ISTAR.CA
<BR>writes:
<BR>
<BR>
MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px">I really LIKE the
<BR>problems, I wouldn't rush to change it. They seem to be a bit kinder
<BR>to the tailsection ... &nbsp;&nbsp;&nbsp;&nbsp;;-)
<BR>
<BR>
bsp;&nbsp;&nbsp;&nbsp;&nbsp;.....bobp
<BR></BLOCKQUOTE>
<BR>
<BR>BOB
<BR>Thats my thought also, thats the reason it's still on there. But I do
have a
<BR>metal spring on hand to do a change out. You were a good excuse to
get it
<BR>done.
--part1_39.11410427.27ceb235_boundary--
