wing tip wiring
apat
wing tip wiring
Post by apat » Fri Feb 17, 2012 8:47 pm
Received: from smtp.interlog.com ([154.11.89.176])
by dcsol.com (wcSMTP v5.4.449.1)
with SMTP id 381449421; Wed, 28 Feb 2001 09:02:51 -0900
Received: (qmail 23891 invoked from network); 28 Feb 2001 18:02:48 -0000
Received: from unknown (HELO ip135.toronto81.dialup.canada.psi.net) (154.20.75.135)
by bretweir.total.net with SMTP; 28 Feb 2001 18:02:48 -0000
Mime-Version: 1.0
Subject: Re: Fw: wing tip wiring
Hi Rebel 505 !
Many builders now run tubes through the wing, so that the wires
can be easily replaced if they should deteriorate years later. It also
makes it easy to add new wires later, if you add strobes, etc. Many
production aircraft use grommets & tie-wraps, forcing the owner to
have the wing opened just to replace wires ! Some early builders
used rigid PVC tube, but lately, many have found the clear flex
tubing much easier to install. The plastic is considered safer
than aluminum, because the wires are less likely to rub through
and short out on it.
You are absolutely going the right way, by running your wires
down inside the strut, along with the pitot tubing. This makes everything
MUCH easier and tidier to connect to the panel !
Just suggestions ........ ;-)
--------------------------------orig.-----------------------------------
At , you wrote:
At 10:05 PM 2/26/01 -0700, you wrote:
To: murphy-rebel@dcsol.com.Sales.Department
Sent: Monday, February 26, 2001 10:01 PM
Subject: wing tip wirring
Hello from Calgary
I drilled holes in the tip ribs and installed rubber grommets to pull my
wires for wing tip lights through. Is this looking for trouble. Should I run
aluminum tube or plastic hose to feed my wire through. The wire will run
down the strut, not straight through to the fuselodge.
All comments will be appreciated,
REBEL 505
<HTML><HEAD>
<META content="text/html; charset=iso-8859-1" http-equiv=Content-Type>
<META content="MSHTML 5.00.2919.6307" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=#ffffff>
<DIV>&nbsp;</DIV>
<DIV style="FONT: 10pt arial">----- Original Message -----
<DIV style="BACKGROUND: #e4e4e4; font-color: black"><B>From:</B> <A
href="mailto:carol51@attcanada.ca" title=carol51@attcanada.ca>carol51</A>
</DIV>
.Department</A>
</DIV>
<DIV><B>Sent:</B> Monday, February 26, 2001 10:01 PM</DIV>
<DIV><B>Subject:</B> wing tip wirring</DIV></DIV>
<DIV><BR></DIV>
<DIV><FONT size=2>Hello from Calgary</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>I drilled holes in the tip ribs and installed rubber
grommets
to pull my wires for wing tip lights through. Is this looking for trouble.
Should I run aluminum tube or plastic hose to feed my wire through. The wire
will run down the strut, not straight through to the fuselodge.</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>All comments will be appreciated,</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT size=2>REBEL 505</FONT></DIV></BODY></HTML>
