Floor Cleaning, Was: Re: [rebel-builders] Polygone - Proseal
David A. Ricker
Floor Cleaning, Was: Re: [rebel-builders] Polygone - Proseal Polysulfide ea
Post by David A. Ricker » Sun Feb 19, 2012 11:35 pm
John
You should have a pretty good solution close by, I have found Avga$ to
do a good job on a polished concrete floor! Give it a rub with a rag
and wipe up the residue. You won't get everything out if its been there
for a while but it does a pretty good job.
Disclaimer, I'm using some very old 100/130 that I had left over from
another life when I raced cars. About the only thing I have left that
I'd run it in is a lawn mower ;-P
On 11/25/2011 9:41 AM, John R. Davidson wrote:
While on the topic of miracle products...
Has anyone found anything particularly good at removing stains from concrete hangar floors?
I'm sure the best answer is "Don't make them!", which I've tried with only limited success.
The main culprits are ATF, engine oil, outboard engine lower unit oil.
Any suggestions would be appreciated.
John
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1869 / Virus Database: 2092/4624 - Release Date: 11/18/11
Internal Virus Database is out of date.
