[rebel-builders] heater questions
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:35 pm
It'll never cook you out..so yah go for it! Go to the hardware store and get
a length of "jack chain". Same stuff that runs the tail wheel. Wrap it
around the pipe in the shroud area. Retain with safety wire or if your's has
the solid collars at each end where the cover clamps over.. drill a hole in
the collar and use a cotter pin to retain the chain, then wrap it at about
1" intervals and cotter at the other. Then safety wire it here and there to
keep it from moving/shafing. Adds immensely to surface area for the air flow
to pick up heat.
Sent: Wednesday, November 23, 2011 9:31 PM
Subject: [rebel-builders] heater questions
I have finally installed a heater in my rebel. Is a control really
needed or can I just wire it open in the fall and closed in the spring?
Also I remember reading in one of the tony bingelllis books that a
spring wrapped around the muffler increases the amount of heat. Has
anyone tried this? does it work?
drewjan
Post by drewjan » Sun Feb 19, 2012 11:35 pm
Thanks Wayne I'll get some chain and put it on before I close the cowl up again. Then try to figure out my skis.
Sender: mike.davis@dcsol.com
Date: Wed, 23 Nov 2011 21:44:50
Subject: Re: [rebel-builders] heater questions
to pick up heat.
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 11:35 pm
Or if you have the money you could have custom ones built, as per link
example http://www.customaircraft.com/images/stud.jpg
I have two short ones installed (one each side) and they put out an
amazing amount of heat for their size. We need a diffuser in the cabin
to keep from cooking my legs.
Bob.
to pick up heat.
To:<rebel-builders@dcsol.com>
