New Guy Questions
RFierb6707
New Guy Questions
Post by RFierb6707 » Fri Feb 17, 2012 8:40 pm
I'm thinking of a 912s powered rebel built to meet the proposed US "sport
pilot" classification. What kind of payload can i expect considering the 1232
pound gross weight limit? I want a simple day/ vfr ship. Which model should I
buy? Murphy offers the 1057lb ultralight model which apparently has a
lighter empty weight than the 912 powered 1450 gross weight model. Will the
ultralight model handle 1232 pounds or is the 1450 gross weight model
(operated at 1232lbs) the way to go? Lastly, what is a realistic build time
for a first time builder? Thanks much.
Roger and Alice Hoffman
New Guy Questions
Post by Roger and Alice Hoffman » Fri Feb 17, 2012 8:40 pm
On 2/9/01 RFierb6707@aol.com wrote:
"I'm thinking of a 912s powered rebel........What kind of payload can i
expect .........Lastly, what is a realistic build time for a first time
builder?"
Im building the 1650# gross Rebel, so can't answer any of your questions re:
the UL version. However, there was quite a thread re: 912 Rebels in
September last year. If you go to the archives at
http://www.dcsol.com/murphy-rebel/archives.htm , then run a sort by subject,
then scroll a couple pages down you will see them. Check the other archives
in the same manner and you'll probably come up with more info.
Regarding your question about build time, I'm a new builder also. I started
#687R one year ago this month. I've always planned for a 3-5 year build time
(depends on whether I retire next year or not). I'm approaching the end of
construction on the right wing and feel I'm pretty well on schedule.
Hopes this helps.
R. Hoffman #687R
Eugene, OR USA
Contributors' page at:
Visit the book store at:
carol51
New Guy Questions
Post by carol51 » Fri Feb 17, 2012 8:40 pm
I am a carpenter and like to think I'm a fairly handy.
I've never worked with aluminum and as suggested built the tail first.To
increase my confidence I had these parts inspected and all were signed, no
flaws. Like any new project, measure tree times cut once. having built the
first wing in about 300 hours, the second one is going much faster. The
manual is pretty good and builder support has always been there for me.
DON'T HESITATE
GO FOR IT.
Rebel 505
From: "Roger and Alice Hoffman" <rognal@continet.com>
Sent: Friday, February 09, 2001 6:45 PM
Subject: New Guy Questions
builder?"
re:
subject,
archives
started
time
Hopes this helps.
R. Hoffman #687R
Eugene, OR USA
New guy questions
Post by Bob Patterson » Fri Feb 17, 2012 8:40 pm
Hi !
With the 912-S, you'll have a real hot-rod !! The 'ultralight'
Rebels typically weigh just under 600 lb. (596-599), while the standard
Rebel with a 912 would run maybe 60-70 lb more.... Both, that is,
without paint.
<I> would definitely build the 'standard' (amateur-built) Rebel.
The 1450 gross is purely a "suggestion" - this is the SAME Rebel kit
as the O-235 & O-320 specs. If you go with that one, you can always
change your mind later, and go to a larger engine, in 'Experimental'.
There is little difference in performance between the 2 Rebels -
they should be virtually identical at the same gross weight.
The U/L Rebel has many differences that make it much less rugged
- many skins are .016 instead of .020, ALL of the control surfaces are
fabric covered, the wing spars are lighter, and the wing struts are
flattened tubes, rather than the massive custom extrusions ....
This makes for dazzling performance with the 912, but, for the
few extra pounds it would take to go to the amateur-built version,
you get a more versatile airplane. The resale value would be much higher
for the standard Rebel, as well, I would expect.
One consideration in building is the size of the fuel tanks.
For the 912, it is just plain SILLY to build the full 6 rib bays of
tank !! This nominally gives 44 gallons, but in practice it's more
like 49 gallons - enough for 12 HOURS with the 912 !!! Most builders
choose to trim the tank skin down & move the solid bulkheads in -
a good choice would be one bay on the left, and 2 on the right -
giving 21 - 24 gallons. This will save weight, and leave more
room for useful load, while avoiding problems with condensation
from half-full tanks. If you are considering someday going to a
larger engine, then you <could> add one more bay per side.
First-time builders have been averaging about 1200 hours, but
the range is large - from 675 hours to 2000+ hours !! We have two
builders who built their Rebels over ONE winter - delivered in Sept.,
flying in July !! ...... and several who have had their kits for over
5 years, as well. Heck, Rebels #003 & #007 (1991) still aren't finished
- but they're still being worked on ! Serial numbers are now over
700 !! Whichever way you go, the Rebel is one of THE easiest kits
on the market to build !
You will LOVE your 912 powered Rebel !! We've had 10 GREAT
years flying ours, and it REALLY <IS> "CHEAP, FUN FLYING" !!!
---------------------------------orig.---------------------------------
Fri, 9 Feb 2001 08:58:58 EST
New guy questions
Post by Ralph Baker » Fri Feb 17, 2012 8:40 pm
We are first time builders on Elite 611E so I guess entitled to at least
$.01 worth. I suggest the following:
You CAN do it with a moderate skill level. No need to be a tool maker or
engineer.
The Murphy quality is excellent with jigless assembly.
Although the tool list is not great there are some necessities. I
suggest for power tools:
4" table mounted belt sander.
1/2" capacity, 1/2HP bench drill press.
5HP air compressor. (Check for max CFM as they vary quite a bit)
Air powered rivet puller. (Should cost about $90)
Air die grinder with 3" aluminum cutoff discs.
Dremel variable speed hand tool.
General hand tools also are required. I would include a right angle drill
attachment, hand nibbler, fly cutter, hand seamer, in addition to the usual
clecos, cleco pliers and drill bits. Don't try to do quality work with
improper tools. (And don't ask how I know.) Get a copy of FAA publication
C37.13, Approved Methods of Alteration and Repair and Tony Bingelis series
of 4 books on homebuilding (available from EAA). Be sure you have the
family approval and support of the project both in time and cost. Realize
it is like eating an elephant and it is one bite at a time. Actually I
find it helpful to look at construction as a series of small projects to
avoid the "overwhelmed" sense. Also, we have not set a time line. It will
take as long as it takes to do the best quality job we are capable of.
Darryl has been quoted as saying "it's not a rolex watch" and inevitably
there will be some places you are not as proud of. Do not lower the
quality goal, and never compromise a structural area. Try to do something
every day. Join EAA and utilize the resources available such as this
group. Don't build just to fly, enjoy the building process with the goal
of being able to say "yes, I built it myself". A good start is assembling
the printed material including what I have referenced above and the
catalogs such as Aircraft Spruce and Aircraft Tool Supply Co. Check prices
as they vary considerably. One tool I did not mention above is our Sioux
brand 3600 rpm 1/4" chuck drills. These are about $200 and worth every
penny. Another is an electric screwdriver with single flute deburring bit.
Susan, the Deburring Queen, would probably give up her BMW motorcycle than
either of those tools.
This has gotten a little long but I hope you feel it is useful as most of
what is on the list is for those who are already immersed. I can say that
I enjoy going out to our hangar every day to work on what will be N624E
before the end of the year. Please feel free to contact me off the list if
you wish.
