[Bulk] Re: [rebel-builders] And the saga continues...Rebel #
Bruce Rose
[Bulk] Re: [rebel-builders] And the saga continues...Rebel #56 Build
Post by Bruce Rose » Sun Feb 19, 2012 8:54 pm
Roland: You have to find out where you made the mistake before you try to
fix the problem or it may happen again. Can you write the exact procedure
that you used to line up the wings to the fuselage.
Bruce
Sent: Tuesday, August 23, 2011 2:22 PM
Subject: RE: [Bulk] Re: [rebel-builders] And the saga continues...Rebel #56
Build
Thanks Ron,
Haven't messed up too many parts during my build... thus this came as a
shock. By the "box" I meant the forward frame or cage. Obviously something
happened between the measurement and the drilling. Even though I was
extremely careful, used two digital levels, etc. I must have checked them
5-6 times before drilling.
Already have a request into MAM for new parts. I know they won't be cheap,
but then again what is these days.
Roland
R56
