[rebel-builders] flap drains
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:54 pm
I have pics of the process, which I did back in June, on my site. See
http://n254mr.com, search for "drain grommets". Cut holes in D shape
(assuming seaplane-type), apply 2-3 coats of Poly Tack under, 8-10 min
apart, apply drain, put dollar patch over top, a coat of pink, shrink patch,
especially edges, then 3 more coats of pink, then silver.
Ron
On Sat, Aug 20, 2011 at 9:49 AM, mike jones <mfjrebel007r@cogeco.ca> wrote:
Hi all
Does anyone have pics of their flap drains, poly fibre says to cover with
strip of fabric, I forgot to install and have sprayed the silver protective
coat on the flaps, do I know have to remove all of it to glue the drain on
with polytack
Mike#007
mike jones
Post by mike jones » Sun Feb 19, 2012 8:54 pm
Fantastic, thanks very much ron, looks great, did not guess to cut hole in
dollar patch, thought it would just go right over top
Mike#007
Shannon
Sent: Saturday, August 20, 2011 10:34 AM
Subject: Re: [rebel-builders] flap drains
Ron
Hi all
protective
with polytack
Mike#007
Ron Shannon
The photos from that search aren't the best. I think I have some more I'll
try to get posted.
To cut the hole in the dollar patch, fold them in half. Like everything else
in the &#$@! plane, I had to make several of these before I got them right,
with holes reasonably well centered, etc.
Ron
Mike#007
Post by Ken » Sun Feb 19, 2012 8:54 pm
Apologies if stating the obvious but melting the final (or all) of the
holes with a soldering pencil or hot nail is recommended. It can be the
last thing or even after painting.
try to get posted.
in the&#$@! plane, I had to make several of these before I got them right,
Ron
Mike#007
