You should use spots of Poly-Tack all around and a few spots
in the middle. If you don't glue it down, it could bunch up ....
I'm assuming it is Polyester Batting (1/4 or 1/2" thick ...)
Not too much adhesive, because the air has to flow through
the batting & out .... to avoid pinholes in the fabric. Don't worry
about it touching the top wing skin - you can use a long piece
of slotted wood to bend it up - OR -- better yet, add Mylar tape
to the flapperon top front, to you can have a tight fit with
no wear. Anyplace that sells stuff for gliders will have the tape -
it's SOP for gliders .... air gaps are drag ....
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
On Thursday 18 August 2011 22:39:57 Charlie Eubanks wrote:
I have started covering the flapperon and am presently attaching the
flannel batten material to the leading edge. Could some body please define
the term "sufficient adhesive to secure the batten"? I would assume the
batten material should be able to move freely as the fabric is being heat
shrunk so it does not bunch up under the fabric?
Charlie E. 802R
