Does your engine weight include the PSRU? If so, which eng and gear
unit did you use? Thanks, Craig
On Tue, Aug 16, 2011 at 4:39 AM , Ken wrote:
You will find that the consensus here is to leave the firewall where
it is which I might agree with if it is already installed...
Fundamentally I agree with Daryl Murphy though. My soob weighs about
the same as an 0-320 and I'm very glad I moved the firewall back. Lots
of discussion in the archives. It is more work than it might appear.
Slightly less visibility as it moves the pedals and seats back as
well. However on wheels I still find it a challenge to get the tail
down on 3 point landings. On amphibs (which moves the cg farther
forward) I find the nose tends to dig in after touchdown when landing
without a headwind. So I also agree with those who suggest shortening
all the float struts and spreader bars from what the manual says. Prop
spray has never been an issue for me.
If you neglect minor structural advantages though, moving the battery
to the tail will move the cg farther than moving the firewall back!!!
My batteries are unusually small and light but they are on the
backside of the firewall where they theoretically reduce ground
looping tendencies compared to aft mounting. EVERYTHING is a
compromise of something.
subaru
quietest engine of the field ;)
On 8/16/2011 7:44 AM, Doug Farrow wrote:Hi Wayne Different TopicIm new to the Forum I bought #778R and Im
going to finish it (over half done)The firewall has not been
shortened (3 inches) and Im planning on an o-320 and 1800 Amphibs.
Could I have anyones thoughts on too shorten or not. ThanksDoug
Farrow778-RHaliburton Ontario
