[rebel-builders] Re: [rebel-builders] Re: [rebel-builders] B
[rebel-builders] Re: [rebel-builders] Re: [rebel-builders] Bent gear leg
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:54 pm
Send me a picture, if you can, with a straight edge on the area..... I
should be around for a couple days yet here.
If need be.. a piece of good oak on each side and 0.041 safety wire to tie
it all together would be a good insurance policy !
Sent: Monday, August 15, 2011 6:08 PM
Subject: Re: [rebel-builders] Re: [rebel-builders] Re: [rebel-builders] Bent
gear leg
Yah it was Ben that made some mods to his gear.. me mixed up. How bent is
bent??
Sent: Monday, August 15, 2011 6:00 PM
Subject: [rebel-builders] Re: [rebel-builders] Re: [rebel-builders] Bent
gear leg
No, I used what I got in the kit from you. If its standard tube I'll get
some from acs. Hopefully it doesn't snap before I can get it back to my
hangar/workshop which is 1000 miles away, and I don't have time to deal
with it until I'm done working for the season in October.
----- Reply message -----
Subject: [rebel-builders] Re: [rebel-builders] Bent gear leg
Date: Mon, Aug 15, 2011 12:38 pm
They bend once... then they snap! Most don't catch the bend first and
glad
you did !
To be sure it's identical to what you have.. cut your own from 1.25 x
1.25
square x 0.125 6061-T6 tube, that you should be able to source from
someone
there in the State.
That said.. didn't you build your own legs or was that someone else I've
got
you mixed up with!?!
Sent: Monday, August 15, 2011 2:15 PM
Ok, what is the best way to get parts these days? Bob P?
Subject: [rebel-builders] Bent gear leg
Date: Mon, Aug 15, 2011 10:27 am
Replace! (Sorry) ! ;O)
Sent: Monday, August 15, 2011 12:09 PM
