[rebel-builders] RE: Thrust bearing
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:51 pm
Charlie,
I bought my planetary bearing from a fellow who used to make them,
named something like Eddie Tohikian (sp?). I don't know if he's still
around or has any left -- mine was one of the last over 4 yrs ago --
but I'll try to find his correct last name and a contact address for
you. The bearing can be seen at http://n254mr.com/node/1749
Ron
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:51 pm
Mike & Ron
Thanks for the info on the planetary vs. spherical bearing for elevator
travel. I am aware of Wayne's procedure of using the steel tube to obtain
max rotation. About a year &
Ron Shannon
I can't tell you much about the innards of this planetary gear, but
thanks to Google, I did find Eddy Tohikian on Facebook (!) and sent
him a message inquiring if he has any more of them. It's probably a
long shot, but I will let you know what I hear. If he doesn't have
any, I'll ask if plans are available.
It works great. The only downside is it was about $90 five years ago,
and it's a little hefty.
Ron
On Thu, Jun 30, 2011 at 5:41 PM, Charlie Eubanks
<rebel802@centurylink.net> wrote:
[quote]Mike & Ron
Charlie Eubanks
Ron
Thanks for all your effort I know you have your hands full getting ready for
Oshkosh. Your right about it being a little pricy so don't spend a lot of
time on it. I have the machinery to build one but I will try Wayne's
procedure first.
Charlie E. 802R
Sent: Thursday, June 30, 2011 8:35 PM
Subject: Re: [rebel-builders] RE: Thrust bearing
[quote]I can't tell you much about the innards of this planetary gear, but
Ron
[quote]Mike & Ron
Ron Shannon
Just heard back from Eddy T., already. [Wow, what a world we live in.]
He's moved on to an RV-8. No bearings left, only made a few, says he
gave blueprints to Murphy, hoping they'd use it in kits, but... not.
Ron
On Thu, Jun 30, 2011 at 7:35 PM, Charlie Eubanks
[quote]Ron
procedure first.
Charlie E.
mikeh
Post by mikeh » Sun Feb 19, 2012 8:51 pm
On 6/30/2011 6:35 PM, rebel802@centurylink.net wrote to rebel-builders:
Charlie, Waynes method works great, I have the same elevator travel as you
and plenty of extra movement/swivel in the rod ends. Cheers Mike
Charlie Eubanks
Thanks for trying. Hope to see you at Oshkosh
Charlie
Sent: Thursday, June 30, 2011 10:02 PM
Ron
Ron
for
procedure first.
Charlie E. 802R
Charlie Eubanks
I plan to try Waynes method first, just wanted to make sure I had other
options.
Charlie E. 802R
Sent: Friday, July 01, 2011 5:59 AM
