Rebel Door Hinge Rivets
Terry Dazey
Post by Terry Dazey » Sun Feb 19, 2012 8:51 pm
Hello Rebel Builders:
Rebel Manual 23.0 Door Assembly (29/06/98) Pg.7, Number 17
The manual says to attach the door to the forward vertical stainless hinge using 1/8 x 1/8 Stainless rivets (assumed RV5402). Unfortunately, I do not have the RV5402's on my MAM packing list and none in stock. The closest stainless rivet I have in my stock is RV5404 (1/8 x 1/4) which look a bit long for the thickness of material. Is this an acceptable rivet or should I order some RV5402's for the application?
Thank you in advance for information.
Terry Dazey
Rebel 662
Lake Tapps, Washington USA
mikeh
Post by mikeh » Sun Feb 19, 2012 8:51 pm
On 6/12/2011 5:57 AM, dazey@turbousa.com wrote to rebel-builders:
-> Hello Rebel Builders:
-> Rebel Manual 23.0 Door Assembly (29/06/98) Pg.7, Number 17
-> The manual says to attach the door to the forward vertical stainless
-> Thank you in advance for information.
-> Terry Dazey
-> Rebel 662
-> Lake Tapps, Washington USA
Hi Terry,
I have used aluminium rivets in 818R.......because I forgot! I've
decided to go with them for now and keep an eye. I figure if there is going
to be a problem it will be with the upper and lower ones and I'll replace
them with stainless if required. Hope this helps.
Cheers Mike
