Yes, I see that now. Thanks for that tip. Duh! Craig
--- oifa@irishfield.on.ca wrote:
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Subject: [rebel-builders] Craig - safety cables
Date: Fri, 22 Apr 2011 21:07:19 -0400
Craig... the big yellow machine is looking great!
Do yourself a big favour and move that cable tang from the lower strut
attach bolt to the inboard axle/gusset retention bolt. The tang bolted on
with the same bolt that holds the strut will do you no good when it rips out
of the gusset plate.... but with the tang attached to the bolt beside it
you'll get the "save" you're looking for.
What you've done is what the SCub guys do.. because they have no other
choice. One great thing we have with the bolted in axle is a better place to
attach that cable to.
Sent: Friday, April 22, 2011 9:35 PM
Subject: Re: [rebel-builders] Craig - safety cables
out
