[rebel-builders] Gord Mohr's Bushings - Bolt ?
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:50 pm
Nytrol has worked just fine over time... but MDRA won't pass it. You have to
have castle nuts and cotter pins on all landing gear "pivot"points to pass
inspection
Sent: Wednesday, April 27, 2011 10:06 AM
Subject: [rebel-builders] Gord Mohr's Bushings - Bolt ?
Logic tells me that there should be a castle nut that goes on the bolt
through Gord's landing gear bushing, but the plans call out for a fibre
nut.
Is that correct? Is there anywhere else that the group recommends putting
on
a castle nut and pin instead of what the plans call for?
Roland
R56
drewjan
Post by drewjan » Sun Feb 19, 2012 8:50 pm
All the landing gear pivot points need castle nuts. I had to change mine to pass inspection.
Sender: mike.davis@dcsol.com
Date: Wed, 27 Apr 2011 10:06:22
through Gord's landing gear bushing, but the plans call out for a fibre nut.
Is that correct? Is there anywhere else that the group recommends putting on
Roland
R56
Jones, Michael
Post by Jones, Michael » Sun Feb 19, 2012 8:50 pm
Oooops guess I better change mine right away, missed that one,
This site is always so helpful, thanks wayne
Ps-best wishes to the family wayne
Sent: April 27, 2011 10:24 AM
Subject: Re: [rebel-builders] Gord Mohr's Bushings - Bolt ?
have to
pass
inspection
fibre
nut.
putting
on
Roland
R56
Thanks Mike... Jen's out of chemo #8 and heading for a full week long chemo
#9 on the 9th of May. So she has #9 and #10 to go and then surgery in late
June to remove her entire right pelvic bone, 1/2 her sacrum. Nothing gets
put back and it's expected of scar tissue and existing muscles to hold her
leg on and make it work. Gonna be a long road..... especially for someone as
sports oriented as she is.
From: "Jones, Michael" <Michael.Jones@snclavalin.com>
Sent: Wednesday, April 27, 2011 11:00 AM
Subject: RE: [rebel-builders] Gord Mohr's Bushings - Bolt ?
have to
pass
inspection
fibre
nut.
putting
on
Roland
R56
Jones, Michael
Wow, that's a lot for the poor girl to handle, keep your faith
cheers
Sent: April 27, 2011 11:33 AM
chemo
late
gets
her
someone as
have to
pass
inspection
bolt
fibre
nut.
putting
on
Roland
R56
rick greenwood
Post by rick greenwood » Sun Feb 19, 2012 8:50 pm
Hello Wayne
It looks like I'm going to have to change my tail pipe hanger,oops didn t see that pic till you pointed it out.Do you know the proper tension on the bolts and springs for the ball joint.Should it be none moveable or slightly moveable?
Good health to Jennifer,I'm sure all will work out well.
Rick
Date: Wed, 27 Apr 2011 11:33:02 -0400
have to
pass
inspection
fibre
nut.
putting
on
Roland
R56
