[rebel-builders] Elevator trim fairing (was Elevator - SR)
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 8:42 pm
It is nice and hopefully they offer similar fairings in different sizes
schaumr@dcsol.com
Sent: Saturday, March 26, 2011 5:38 PM
Subject: [rebel-builders] Elevator trim fairing (was Elevator - SR)
Update: I just noticed on Eric's site a very nice trim fairing (which I'm
hoping
is off someone's shelf somewhere).
Here's a shot from Eric's website...
http://www.efogelin.com/aviation/murphy ... ent/IMG_20
080619_017_large.html
Anyone know where to get this?
Rob
Rebel 786
On 3/26/2011 4:38 AM, schaumr wrote to oifa@irishfield.on.ca:
-> Hi Wayne,
-> Hope you are well. I was perusing any discussions around elevator trim
push-
-> rod fairings and came across your description below. Tried to find the
photos
-> you are referring to, but perhaps they were lost in one of Mike's server
-> glitches or transfers...I recognize it might be hard to keep track of
photos
-> uploaded about nine years ago!!
-> Any chance you might still have them somewhere? Do they look anything
like
-> the ones I made for the rudder cables exit holes:
-> http://mykitlog.com/users/display_log.php?
-> user=schaumr&project=724&category=0&log=113367&row=6
-> While fairings are not my favorite things to fabricate, this particular
fairing
-> would be more to would help limit dust and debris in the trim servo
-> compartment than for aesthetic/aerodynamic reasons; I'm thinking
anytime
-> you'd apply power while on the ground, stuff will get kicked up around
-> elevator.
-> Anyone else found anything off-the-shelf that works?
-> Rob
-> Reel 786
-> On 3/8/2002 2:09 PM, OIFA@IRISHFIELD.ON.CA wrote to MURPHY-REBEL:
-> -> Hi Everyone!
-> -> One day I should take Bob P's (and my own advise) and just build these
-> -> things "as is" and get them flying. Added about 6 hours of work to the
-> -> Elevator while finishing up the 3500 mods and final closing of same.
-> -> I couldn't stand the look of the elevator's outboard ends, with the 4
-> -> tooling holes and the rib flange cut outs at the main spar, so I
fabricated
-> -> .020 covers for each end and moved the .032 tip weight reinforcing
-> doublers
-> -> to the inside of the tip. The tip weight doublers pick up the rivets
of the
-> -> outside cover around the perimeter of the weights. I also moved the
-> inboard
-> -> tip weight doubler to the inside of the rib in the same fashion
(riveted
-> -> around the perimeter) for a much cleaner look and to leave me some
more
-> -> clearance between the tip and the stabilizer.
-> -> I also fabricated a fairing for the trim servo rod slot. Really cleans
up
-> -> the looks of the area and also reinforces the area around the slot
(that
has
-> -> to be cut out for the rod to come through).
-> -> Posted 1 picture of the cover and 2 of the trim fairing to SR tail
feathers.
-> -> (or just click new)
-> -> Cheers,
-> -> Wayne G. O'Shea
-> -> www.irishfield.on.ca
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 8:42 pm
Thanks for looking at the site. I used the same fairings for the rudder
cable exit as well. They are from Aircraft Spruce. ABS plastic so you can
paint them. I will look up the part number...
N645E
schaumr@dcsol.com
Sent: Saturday, March 26, 2011 2:38 PM
hoping
Rob
Rebel 786
-> Hi Wayne,
push-
photos
photos
like
fairing
anytime
-> elevator.
-> Rob
-> Reel 786
-> -> Hi Everyone!
fabricated
-> doublers
of the
-> inboard
(riveted
more
up
(that
has
feathers.
-> -> Cheers,
Eric Fogelin
Here is the Aircraft Spruce part:
http://www.aircraftspruce.com/catalog/a ... irings.php
It is under Control Cable Fairings.
Cost is $4.35 and you get a pair. So, price is right...
N645E
schaumr@dcsol.com
hoping
Rob
Rebel 786
-> Hi Wayne,
push-
photos
photos
like
fairing
anytime
-> elevator.
-> Rob
-> Reel 786
-> -> Hi Everyone!
fabricated
-> doublers
of the
-> inboard
(riveted
more
up
(that
has
feathers.
-> -> Cheers,
schaumr
Post by schaumr » Sun Feb 19, 2012 8:42 pm
Thanks Eric...your site is one of those I go to to see what's possible...then I
go off and try for 70% of that....:)
It's both frustrating and embarrassing to think ACS had these all along....so I
went back and searched 'fairing'.....and sure enough these particular fairings
did not show up. Whew...I'm not crazy (at least not today).
Punch in 'fairings' however...and there they are....#4. Talk about flawed
search engines......Now, what other goodies are buried in that catalog?
Rob
Rebel 786
On 3/27/2011 8:27 AM, elist@whidbey.com wrote to rebel-builders:
-> Here is the Aircraft Spruce part:
-> http://www.aircraftspruce.com/catalog/a ... irings.php
-> It is under Control Cable Fairings.
-> Cost is $4.35 and you get a pair. So, price is right...
-> Eric
-> N645E
-> -----Original Message-----
-> schaumr@dcsol.com
-> Sent: Saturday, March 26, 2011 2:38 PM
-> Subject: [rebel-builders] Elevator trim fairing (was Elevator - SR)
-> Update: I just noticed on Eric's site a very nice trim fairing (which I'm
-> hoping
-> is off someone's shelf somewhere).
-> Here's a shot from Eric's website...
-> 080619_017_large.html
-> Anyone know where to get this?
-> Rob
-> Rebel 786
-> On 3/26/2011 4:38 AM, schaumr wrote to oifa@irishfield.on.ca:
-> -> Hi Wayne,
-> -> Hope you are well. I was perusing any discussions around elevator trim
-> push-
-> -> rod fairings and came across your description below. Tried to find the
-> photos
-> -> you are referring to, but perhaps they were lost in one of Mike's server
-> -> glitches or transfers...I recognize it might be hard to keep track of
-> photos
-> -> uploaded about nine years ago!!
-> -> Any chance you might still have them somewhere? Do they look
anything
-> like
-> -> the ones I made for the rudder cables exit holes:
-> -> http://mykitlog.com/users/display_log.php?
-> -> user=schaumr&project=724&category=0&log=113367&row=6
-> -> While fairings are not my favorite things to fabricate, this particular
-> fairing
-> -> would be more to would help limit dust and debris in the trim servo
-> -> compartment than for aesthetic/aerodynamic reasons; I'm thinking
-> anytime
-> -> you'd apply power while on the ground, stuff will get kicked up around
-> the
-> -> elevator.
-> -> Anyone else found anything off-the-shelf that works?
-> -> Rob
-> -> Reel 786
-> -> On 3/8/2002 2:09 PM, OIFA@IRISHFIELD.ON.CA wrote to MURPHY-
REBEL:
-> -> -> Hi Everyone!
-> -> -> One day I should take Bob P's (and my own advise) and just build
these
-> -> -> things "as is" and get them flying. Added about 6 hours of work to
-> -> -> Elevator while finishing up the 3500 mods and final closing of same.
-> -> -> I couldn't stand the look of the elevator's outboard ends, with the 4
-> -> -> tooling holes and the rib flange cut outs at the main spar, so I
-> fabricated
-> -> -> .020 covers for each end and moved the .032 tip weight reinforcing
-> -> doublers
-> -> -> to the inside of the tip. The tip weight doublers pick up the rivets
-> of the
-> -> -> outside cover around the perimeter of the weights. I also moved the
-> -> inboard
-> -> -> tip weight doubler to the inside of the rib in the same fashion
-> (riveted
-> -> -> around the perimeter) for a much cleaner look and to leave me
some
-> more
-> -> -> clearance between the tip and the stabilizer.
-> -> -> I also fabricated a fairing for the trim servo rod slot. Really cleans
-> up
-> -> -> the looks of the area and also reinforces the area around the slot
-> (that
-> has
-> -> -> to be cut out for the rod to come through).
-> -> -> Posted 1 picture of the cover and 2 of the trim fairing to SR tail
-> feathers.
-> -> -> (or just click new)
-> -> -> Cheers,
-> -> -> Wayne G. O'Shea
-> -> -> www.irishfield.on.ca
-> List archives located at: https://mail.dcsol.com/login
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:42 pm
I have complained about ACS's search engine to them for years. In addition
to singular/plural issues, lots of things are indexed only under descriptive
adjectives, but not the nouns, etc. The hard copy print catalog index is
almost as bad.
These squawks fall on deaf ears there it seems and no wonder, I suppose,
because I keep buying stuff from them anyway. Oh well.
Ron
N254MR
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:42 pm
Don't any of you keep a paper copy of the ACS catalogue beside the throne in
the think room??
;O)
Sent: Sunday, March 27, 2011 1:46 PM
Subject: Re: [rebel-builders] Elevator trim fairing (was Elevator - SR)
descriptive
almost as bad.
Ron
N254MR
flawed
