[rebel-builders] Question of Rebel Datum location/ Cof G ran
[rebel-builders] Question of Rebel Datum location/ Cof G range
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:41 pm
I don't have anything in the hangar Curt.. with the cylinder mounted to the
floor... mine are still on the pedal tab, as are the other two in the
stable.
I'll see if I can dig up a picture or two of when I moved them to the floor
in FOKM.
Sent: Monday, February 14, 2011 8:58 AM
Subject: Re: [rebel-builders] Question of Rebel Datum location/ Cof G range
Hey Wayne,
While your in the measureing mode, could you give me an approxmate
distance of how far forward of the rudder tube you move the bottom of the
brake master cylinder? Found an interesting artice in kitplane mag a
while back that stated the top of the brake pedal should move 1.5 to 2.0
x's as for as the attach point of the master cylinder. I always wondered
why we have the same calipers as a 172 and cannot hold it above 1900
static. Now, how to do the most good with the least amount of intrusion!
As always, thanks for your help
Curt Martin
N97MR
Sent: Sun, Feb 13, 2011 8:16 pm
range
As I alluded to before Jason.. Call your MDRA inspector.. they seem to
have
n issue with no negative numbers in your W & B calculations. I guess
lexander can't figure out subtraction.....
If that is the case.. use your nose wheel or the end of the float deck as
our datum so everything is postive behind it. Be sure to get an accurate
easurement to the center of the door post or leading edge for when you
witch to conventional gear and to convert the Murphy 7.7 to 19.7 (or what
ver the current spelled out) WING range to reflect your datum.. IE: your
mpty C of G range is now gonna be MAM's numbers PLUS the distance from the
eading edge to the nose wheel or float deck end.
rom: "Rebecca Brownell" <brownell@cottagecountry.net>
ent: Sunday, February 13, 2011 8:06 PM
Maby somebody could walk me through how to figure it all out when
weighing it on amphibs.Can't get it!!!!!
Jason
On 13-Feb-11, at 5:51 PM, Ron Shannon wrote:
OK, I'll just take Wayne's empirical data report here as [almost]
complete
vindication of the probable accuracy, propriety, virtue, brilliance,
etc.,
of my previously described measurement (spring gear axle center @ 0.5"
forward of leading edge) and -- quite uncharacteristically -- say no
more.
And definitely, worry no more. ;-)
Ron
PS - Reporting in from Quenca, Ecuador, where we recently completed
a hike
to and around 3979m (13,054 ft.) -- and lived to tell about it.
On Sun, Feb 13, 2011 at 10:22 AM, Wayne G. O'Shea <oifa@irishfield.on.ca
wrote:
Okay.. so todays investigation.. just to make it all into real
thick mud.
The Spring LEAF gear... without any extreme regard for measuring
accuracy...
with a leg on the work table, the axle centerline appears to be
7/8" AHEAD
of the door post center line!
