[rebel-builders] Question of Rebel Datum location/ Cof G ran
Rebecca Brownell
[rebel-builders] Question of Rebel Datum location/ Cof G range
Post by Rebecca Brownell » Sun Feb 19, 2012 8:35 pm
Oh how badly I want to.Get this paperwor filled out ,get a new fuel
line made from where I removed that fuel flow meter.Inspection next
week and away we go.Oh the hydraulic pump.Darryl emailed and said it
would be going out next week but that will go in quick.
On 13-Feb-11, at 9:24 PM, Wayne G. O'Shea wrote:
9.18 empty c of g.. bolt the sucker down, fill the tanks and go
flying!
From: "Rebecca Brownell" <brownell@cottagecountry.net>
Sent: Sunday, February 13, 2011 9:17 PM
Subject: Re: [rebel-builders] Question of Rebel Datum location/ Cof
G range
Lets give it a go.Here's the numbers;Right rear 476 left rear 457
fronts together 291
34.5'' from mains to door post
72'' from fronts to door post
Total weight 1224
total weight on mains 933
Battery is now at 106 aft of door post
battery weighs 15.5 lbs
It will need to come ahead but by how much?
On 13-Feb-11, at 9:03 PM, Ken wrote:
Level the door frame. Be careful as I needed the rear amphib
wheels at
least a foot high to level the door frame.
Drop a plumb bob from the leading edge of the wing.
Measure horizontal distance from plumb bob to front axles and from
plumb
bob to main wheel axles.
Take another measurement from the plumb bob to whatever you are
using
for a datum if using something other than the leading edge.
Personally
I'd use the leading edge unless MDRA can invent a legal piece of
paper
that says otherwise. Makes the math easy. Makes the result easy to
interpret. Makes converting to wheels easy.
Weigh all wheels. If you don't have enough scales also level it left
right before every reading.
If you have those numbers give them to us and I'll walk you through
math if you like. Others might benefit from the exercise or at least
critique us ;)
I can use my numbers for seat, fuel tank, and baggage position or
you
can measure those distances from the plumb bob as well.
(or was that not the problem?)
On 2/13/2011 8:06 PM, Rebecca Brownell wrote:
