[rebel-builders] Question of Rebel Datum location/ Cof G ran
[rebel-builders] Question of Rebel Datum location/ Cof G range
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:35 pm
LOL
From: "Rebecca Brownell" <brownell@cottagecountry.net>
Sent: Sunday, February 13, 2011 9:15 PM
Subject: Re: [rebel-builders] Question of Rebel Datum location/ Cof G range
Thats OK.I got to admit I was nearly sick.
On 13-Feb-11, at 9:11 PM, Wayne G. O'Shea wrote:
Sorry for the scare there Jason.. that would be ~ 74 inches to the
nose
wheel... so c of g range.. 84.7 to 96.7... or there abouts.
Sent: Sunday, February 13, 2011 8:42 PM
G range
So Jason... I'm not being exact.. but I looked at my own amphib w &
b....
nose wheel is 54 inches ahead of wing leading edge or there abouts...
suspect that makes the top front edge of the float deck around 57
inches
forward of the leading edge... so if Muphy's allowable c of g range
is
stated as 7.7 to 19.7 (or if you want to use the newer one do so)..
you'd
have a allowable c of g range of 64.7 to 76.7" aft of "datum", if
your
front
edge of the float deck is now your datum point. Of course you need
to use
your own numbers as you may have mounted them more aft or fwd than
I did.
Sent: Sunday, February 13, 2011 8:32 PM
range
