[rebel-builders] C.G.
Post by Walter Klatt » Sun Feb 19, 2012 8:35 pm
Don't know where the 12 came from, but I think this is still the latest
recommendation from MAM.
http://www.pattersonaerosales.com/Aircr ... ulletin.pd
f
My empty c of g is 10.7, but that goes up with fuel, passenger, baggage,
when flying, so no problem at all for me (on amphibs).
Jenks
Sent: Thursday, February 03, 2011 7:34 AM
To: Builders list
Subject: [rebel-builders] C.G.
There is a discrepancy between the construction manual and the fight manual
I have on cd: Construction man. says 12" to 19.7" but doesn't say where the
datum is, and the flight man. says 10.85" to 18.1" measured from wing LE.
Can anyone clarify?
Jesse
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 8:35 pm
Unless you're already very familiar with the Rebel, I'd strongly recommend
loading for a first flight CG of no less than 12.5", preferably 13" or more.
In 254R, even with half tanks, that requires 40+ lbs. in baggage, and that's
with a relatively light engine & 11 lb. prop. A 13" CG gives you at least a
little bit margin for any possible lack of elevator authority you may find
in your initial elevator deflection setup.
Also, before flying be sure to actually measure the length of the arm (belly
button position) of the real pilot, sitting in the seat where he will want
it during first flight. I wanted the see rather far forward, and made the
mistake of relying on the sample manual's suggestion (15" as I recall) which
turned out to be long by almost 3". I had used the 15" from the sample
manual when I was in a hurry to come up with a first flight W&B config. for
the FAA paperwork, and forgot to actually measure it, until later. Wrong.
Ron
f
Jesse
Jenks
To: Builders list
Can anyone clarify?
Jesse
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:35 pm
Thanks for the help guys, I guess I'll go with what the service bulletin says and that matches with the POH. Bob, the 12" is right out of the construction manual in the weight and balance section. I don't know what they were smokin when they wrote that thing, but it must have been good.
Date: Thu, 3 Feb 2011 10:36:32 -0800
Subject: Re: [rebel-builders] C.G.
Ron
f
Jesse
Jenks
To: Builders list
Can anyone clarify?
Jesse
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:35 pm
They grow some good stuff in the hills of Chilliwack! LOL
Original EMPTY C of G range was 7.7 to 19.7" aft of datum. (leading
edge/front edge of gear leg) and I continue to use it. Everything you put in
the airplane moves the C of G back. Yes optimal flight is in the 12 to 15"
range, but don't let that confuse the empty C of G limits for the wing.
Even with Bobp's XWI..... it went out of here with an empty C of G of 8.16"
aft of datum, with firewall in original positon, O-320 and Sensenich Prop. I
could still land the thing on it's tailwheel with the mains 2 or 3 feet in
the air. Solo.. with no baggage what so ever and only 15 gallons of fuel on
board.
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Thursday, February 03, 2011 3:53 PM
Subject: RE: [rebel-builders] C.G.
recommend
more.
that's
find
(belly
want
which
for
Ron
f
baggage,
Jesse
Jenks
To: Builders list
manual
LE.
Can anyone clarify?
Jesse
Jesse Jenks
So I hear.
All good info Wayne, but what I was trying to nail down are the loaded CG limits which the flight manual I have on pdf lists as 10.85" to 18.1". As you say, who cares (within reason of course) what the empty cg is as long as you load the plane to get the CG within limits. There are no empty CG limits are there?
I have an 0-320 and metal prop with original firewall location and tail mounted battery, so hopefully my empty CG will not be too forward, but as you say, everything you load in moves CG back, so it seems to me that with such a large baggage area volume to carry all my gear that starting with an empty CG that is a bit far forward is a good thing from a load hauling perspective.
Airworthiness inspection scheduled for next weekend and I still have quite a bit to do...
Thanks.
Jesse
Date: Thu, 3 Feb 2011 16:07:32 -0500
board.
recommend
more.
that's
find
(belly
want
which
for
Ron
All I can tell you Jesse, if you plan to go to amphibs at any point and do
some serious cross country and back lake fishing etc... it is relatively
easy to get carried away with items being stuffed into the airplane where
it's so far aft c of g that it won't roll up on the step.. even with full
fwd stick! So starting nose heavy isn't a bad thing when it comes to that
type of flying. I'll hazard a guess that yours is going to come out at ~ 9"
to 9.7" aft of datum on wheels.
Sent: Friday, February 04, 2011 11:07 AM
So I hear.
limits are there?
perspective.
a bit to do...
Thanks.
Jesse
in
15"
8.16"
Prop. I
in
on
board.
bulletin
what
good.
Jesse Jenks
I forgot to mention the big a$$ tailwheel I have as well so that may throw of your prediction a bit, we'll see on Thursday when I get weighed...but that is exactly the kind of flying I want to be doing, the amphib stuff that is.
Date: Fri, 4 Feb 2011 12:20:19 -0500
So I hear.
limits are there?
perspective.
a bit to do...
Thanks.
Jesse
in
15"
8.16"
Prop. I
in
on
board.
