Dynon remote compass location
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 8:35 pm
What is the best (easiest that works well) location for the Dynon remote compass? Eric, are you here? I was thinking on the ceiling behind one of the bulkheads in the baggage area, or possibly right above the pilot's head next to the torque tube support. Not sure just how isolated or far away from ferrous stuff this thing really needs to be.
Thanks.
Jesse
Post by Ralph Baker » Sun Feb 19, 2012 8:35 pm
Be careful using stainless in any mount or hardware in any magnetically sensitive area. There are magnetic stainless steels.
rogerk
Post by rogerk » Sun Feb 19, 2012 8:35 pm
To find the best place on my Moose, I established the magnetic heading
away from the aircraft and then fired up everything and moved all over
the fuselage with a compass to find the place with the least magnetic
influence. Then mounted the Dynon using a fabricated aluminum bracket
and rivets. The unit now shows correct magnetic direction.
I found it amazing what caused interference as I scanned the fuse.
Mine ended up above the pilots head ...
Good luck.
Roger K
On 1/17/2011 5:55 PM, rebaker@sc.rr.com wrote to rebel-builders:
-> Be careful using stainless in any mount or hardware in any magnetically
-> Ralph Baker
