[rebel-builders] Cable tensions - Was:control cable turnbuck
Ron Shannon
[rebel-builders] Cable tensions - Was:control cable turnbuckles
Post by Ron Shannon » Sun Feb 19, 2012 8:35 pm
Show me a builder who's never over analyzed _anything_ (if you can find one)
and the plane... and I'm guessing I probably wouldn't want to fly in it.
Probably best to not leave more than 3 threads on each side before you hand
tighten the cable for the front Nicopress, because when you come to
balancing or fine tuning everything, including the return spring tension,
you may actually want to loosen one side to keep both pedals even with each
other and the rudder centered. Next thing you know you have to make another
one. Been there.
Hang in there. As I've said before, it turns out all the hard work and
delayed gratification really is ecstasy in the bank, which comes back with
geometrically compounded interest.
Ron
254R
On Mon, Jan 17, 2011 at 8:09 AM, Jason Beall <super_rebel131@yahoo.com>wrote:
.... I think I am over analyizing things sometimes!
