[rebel-builders] Moose/Super Rebel brake issue
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 8:34 pm
Tom,
In brief: The manner in which the brakes are mounted to the floor, in
combination with the design of the right-side brake interconnect bar, can,
if the brake mounts are off just slightly, cause an unrecoverable (in
flight/taxi) pedal lock up. Full L or full R rudder coupled with full brake
can cause the brake linkage to go over-center, thereby locking the pedals
up. Several builders have experienced this while taxiing and were able to
stop and, using a tool (e.g. long screwdriver, pry bar) unlock the pedal.
One builder with approx 60 hours on his plane ground-looped it on
landing/takeoff (can't remember which) resulting in totaling the plane and
having the gear leg break off and come up thru the floor severely cutting
the pilot's leg.
This is a SERIOUS issue. If you don't have dual master/slave cylinders or
some other mod then I strongly recommend you take off the right-side brake
interconnect bar. Immediately.
Pictures are available amongst various builders. Perhaps Murphy is working
on a service bulletin? Anyone know?
thtonner@mymts.net
Sent: Monday, January 10, 2011 7:28 PM
To: Murphy Mailing list
Subject: RE: [rebel-builders] Moose engine choice
Can anyone share a little more information on the right side brake safety
concern. I own a SR2500. this is the first I heard of it and would like to
know what the issue is, how to resolve, etc.
Tom Tonner
Date: Sun, 9 Jan 2011 10:15:47 -0700
Hello Rick,
I have 400+ hours on an M-14P Moose operating at 5,000' in the Denver
area.
No problems with gross weight takeoffs even on very warm days. Cruise is
120 mph at 15.5gph. Anyone that advertises faster cruise than that is full
of !@#@%. I've flown side-by-side with another Moose w/ M-14 and confirmed
speed/gph. Climb perf is about 600 to 800 fpm at medium weight on maybe 60
to 70 degree day at my altitude. I've had it up to 16,500' several times
and it's still able to climb.
O-540's are definitely faster by far.
M-14P's are sexy engines. Parts are easy to get and far, FAR less
expensive
than O-540. One can get an M-14P (overhauled one) for low $20k and new one
for $25K+ if you look around. To my knowledge, O-540's are way more
expensive than that.
MAM never released a service bulletin on the huge safety problem of the
right-brake interconnect. Go figure. I just took my interconnect bar
off/out. Other builders have done a variety of mods to enable right-side
brakes (Cessna mod, custom, etc). I don't miss not having right-side
brakes
at all.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rick
Byers
Sent: Sunday, January 09, 2011 5:35 AM
To: Rebel Builders Group
Subject: [rebel-builders] Moose engine choice
Hi All,
I'm new to the email group. I started a Super Rebel a few years ago,
purchased the Moose Upgrade and had some down time from the building
process. Plan to start up again soon and am still undecided on the M14-P
or
O-540 engine.
MAM has told me that I can complete the fuselage and that the Firewall
will
be built the same up to the engine mounting.
I was hoping to get some feedback from anyone flying Moose with O-540's
M14's on the pros and cons of each. I've read about the peculiarities of
M14 series engines as far as how they differ from the Opposed Engines for
ground operations. I guess what I'm looking for is the actual performance
numbers: Rate of climb, cruise speed, fuel burn. I've seen the advertised
numbers but was just looking for some confirmation.
I currently fly a C-120 out of Bisbee, AZ where the field elevation is
4780
ft. and it's not uncommon to have density altitudes over 8000 ft. in the
warm months. Some days I'm lucky to see 100 fpm climb rate. This is where
I'm wondering about the O-540 with a gross wt airplane.
I've read about a Moose accident where a brake over centered and locked
up.
MAM hasn't responded to my question on that subject yet. Saw some posts by
builders who didn't install the RH side brake mechanism. Is it standard
practice to not install the right seat slave hardware?
Thank you.
Any answers & help is greatly appreciated.
Rick Byers
Hereford, AZ
rogerk
Post by rogerk » Sun Feb 19, 2012 8:34 pm
hi Tom and Ted
For what it's worth, I managed to fix this permanently with a 1/2" piece
of mild steel about an inch and a half long. No chance of over centering
mine now. I can take a photo if you're interested.
Roger K
On 1/10/2011 7:22 PM, ted@vafm.org wrote to rebel-builders:
-> Tom,
-> In brief: The manner in which the brakes are mounted to the floor, in
-> combination with the design of the right-side brake interconnect bar, can,
-> if the brake mounts are off just slightly, cause an unrecoverable (in
-> flight/taxi) pedal lock up. Full L or full R rudder coupled with full brake
-> can cause the brake linkage to go over-center, thereby locking the pedals
-> up. Several builders have experienced this while taxiing and were able to
-> stop and, using a tool (e.g. long screwdriver, pry bar) unlock the pedal.
-> One builder with approx 60 hours on his plane ground-looped it on
-> landing/takeoff (can't remember which) resulting in totaling the plane and
-> having the gear leg break off and come up thru the floor severely cutting
-> the pilot's leg.
-> This is a SERIOUS issue. If you don't have dual master/slave cylinders or
-> some other mod then I strongly recommend you take off the right-side brake
-> interconnect bar. Immediately.
-> Pictures are available amongst various builders. Perhaps Murphy is working
-> on a service bulletin? Anyone know?
-> Ted
-> -----Original Message-----
-> thtonner@mymts.net
-> Sent: Monday, January 10, 2011 7:28 PM
-> To: Murphy Mailing list
-> Subject: RE: [rebel-builders] Moose engine choice
-> Can anyone share a little more information on the right side brake safety
-> concern. I own a SR2500. this is the first I heard of it and would like to
-> know what the issue is, how to resolve, etc.
-> Thanks,
-> Tom Tonner
-> > From: ted@vafm.org
-> > To: rebel-builders@dcsol.com
-> > Subject: RE: [rebel-builders] Moose engine choice
-> > Date: Sun, 9 Jan 2011 10:15:47 -0700
-> > Hello Rick,
-> > I have 400+ hours on an M-14P Moose operating at 5,000' in the Denver
-> area.
-> > No problems with gross weight takeoffs even on very warm days. Cruise is
-> > 120 mph at 15.5gph. Anyone that advertises faster cruise than that is full
-> > of !@#@%. I've flown side-by-side with another Moose w/ M-14 and confirmed
-> > speed/gph. Climb perf is about 600 to 800 fpm at medium weight on maybe 60
-> > to 70 degree day at my altitude. I've had it up to 16,500' several times
-> > and it's still able to climb.
-> > O-540's are definitely faster by far.
-> > M-14P's are sexy engines. Parts are easy to get and far, FAR less
-> expensive
-> > than O-540. One can get an M-14P (overhauled one) for low $20k and new one
-> > for $25K+ if you look around. To my knowledge, O-540's are way more
-> > expensive than that.
-> > MAM never released a service bulletin on the huge safety problem of the
-> > right-brake interconnect. Go figure. I just took my interconnect bar
-> > off/out. Other builders have done a variety of mods to enable right-side
-> > brakes (Cessna mod, custom, etc). I don't miss not having right-side
-> brakes
-> > at all.
-> > Ted
-> > -----Original Message-----
-> > From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Rick
-> > Byers
-> > Sent: Sunday, January 09, 2011 5:35 AM
-> > To: Rebel Builders Group
-> > Subject: [rebel-builders] Moose engine choice
-> > Hi All,
-> > I'm new to the email group. I started a Super Rebel a few years ago,
-> > purchased the Moose Upgrade and had some down time from the building
-> > process. Plan to start up again soon and am still undecided on the M14-P
-> or
-> > O-540 engine.
-> > MAM has told me that I can complete the fuselage and that the Firewall
-> will
-> > be built the same up to the engine mounting.
-> > I was hoping to get some feedback from anyone flying Moose with O-540's
-> and
-> > M14's on the pros and cons of each. I've read about the peculiarities of
-> the
-> > M14 series engines as far as how they differ from the Opposed Engines for
-> > ground operations. I guess what I'm looking for is the actual performance
-> > numbers: Rate of climb, cruise speed, fuel burn. I've seen the advertised
-> > numbers but was just looking for some confirmation.
-> > I currently fly a C-120 out of Bisbee, AZ where the field elevation is
-> 4780
-> > ft. and it's not uncommon to have density altitudes over 8000 ft. in the
-> > warm months. Some days I'm lucky to see 100 fpm climb rate. This is where
-> > I'm wondering about the O-540 with a gross wt airplane.
-> > I've read about a Moose accident where a brake over centered and locked
-> up.
-> > MAM hasn't responded to my question on that subject yet. Saw some posts by
-> > builders who didn't install the RH side brake mechanism. Is it standard
-> > practice to not install the right seat slave hardware?
-> > Thank you.
-> > Any answers & help is greatly appreciated.
-> > Rick Byers
-> > Hereford, AZ
-> List archives located at: https://mail.dcsol.com/login
Bill Maxwell
Post by Bill Maxwell » Sun Feb 19, 2012 8:34 pm
I would be interested, please roger.
Bill
On 12/01/2011 11:17 AM, rogerk@dcsol.com wrote:
hi Tom and Ted
Roger K
-> Tom,
-> the pilot's leg.
-> Ted
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
-> area.
-> expensive
-> brakes
-> > at all.
-> > Ted
-> > Byers
-> > Hi All,
-> or
-> > O-540 engine.
-> will
-> and
-> the
-> 4780
-> up.
-> > Thank you.
-> > Any answers& help is greatly appreciated.
-> > Rick Byers
-> > Hereford, AZ
Miller, Ross W
Post by Miller, Ross W » Sun Feb 19, 2012 8:34 pm
Roger,
I'm not to the brake installation stage yet but planning ahead and would like some pictures. I'm an old flight instructor and definitely going to have breaks on the right too, since I'm going to be flying equally L/R seat. Thanks,
Ross
ross.miller@gdit.com
Sent: Tuesday, January 11, 2011 07:17 PM
To: rebel-builders@dcsol.com <rebel-builders@dcsol.com>
Subject: RE: [rebel-builders] Moose/Super Rebel brake issue
hi Tom and Ted
Roger K
-> Tom,
-> the pilot's leg.
-> Ted
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
-> area.
-> expensive
-> brakes
-> > at all.
-> > Ted
-> > Byers
-> > Hi All,
-> or
-> > O-540 engine.
-> will
-> and
-> the
-> 4780
-> up.
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:34 pm
I think everyone here would love to see your Mod Roger so pics in the
archives would be great. I've had two Elites and a Rebel through here with
dual brakes and I've done everything under the sun and couldn't make them
lock up. Maybe the Moose is a tad different???
Sent: Tuesday, January 11, 2011 7:41 PM
Subject: Re: [rebel-builders] Moose/Super Rebel brake issue
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Ted Waltman
I'm sorry to beat this horse to death on the "potential" Moose brake
over-center issue. I'm not trying to spread rumors and I'm not trying to
malign Murphy Aircraft--just trying to provide builders and those already
flying with a "heads up" to a possible issue.
For a fact, I know that I was able to get my right-side pedal to go
over-center in an extreme full rudder; full brake situation (experimenting
on the ground; not taxiing nor landing/taking off). For a fact I know of
two other builders (I'm not mentioning their names here) who had the pedals
lock up while taxiing. I have pictures that show my pedals in an
over-center position.
I suspect that if one mounts the "Rudder Blocks RP-013" just 1 mm (?) off;
if one isn't very careful with the alignment of these, then perhaps one can
potentially experience this rudder pedal lock up issue. I'm not an engineer
and I haven't experimented with different mounting positions to verify this.
I don't know if the Moose is in any way different than any of the other
Murphy aircraft--all of which are great planes by the way.
All I know is that current builders and those already flying would be wise
to at least inspect this situation on their planes. Maybe they are Ok;
maybe they have an issue--so why not be safe and check?
G. O'Shea
Sent: Tuesday, January 11, 2011 6:05 PM
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Eric Fogelin
Post by Eric Fogelin » Sun Feb 19, 2012 8:34 pm
This issue comes up from time to time. And I did see the wreck of the Moose
with the over center claimed as the cause, but don't know the builder.
I did set up a mockup stand and tried to do the over center trick. It was
difficult. I did manage to do it and it took full left or right control with
opposite brake which is not a normal control input. I did see the over
center problem. So, my "fix" was to ensure the brake pedal could not *ever*
go over center. Photos on my website:
http://efogelin.com/aviation/murphy/lig ... G_20080106_
002_large.html
Hope that long link doesn't get cut up.
Try this if it does.
http://efogelin.com/aviation/murphy/lig ... dex_2.html
I have now flown a total of 200 hours with many of them with pilots and
pilots in training using the brakes from the right seat. They have to really
stomp on them on amphib floats because the mechanical linkage and the really
tiny wheels and brakes on amphibs require serious stomping. No over center
problems to date.
N645E
Waltman
Sent: Tuesday, January 11, 2011 5:25 PM
G. O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Eduardo Gutierrez Sosa
Post by Eduardo Gutierrez Sosa » Sun Feb 19, 2012 8:34 pm
Hi All: I'll go along with Mike; the only way there may be some binding is
if one of the brake master cylinder emptied and the brake pedal hit the
firewall before the rudder pedal reached its furthest deflection, but there
still would leave some rudder during landing/takeoff. Some photos would help
enormously as everyone reading this forum is worried sick about the
possibilities of a pending accident. Regards, Eduardo
-----Mensaje original-----
De: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] En nombre de Wayne G.
O'Shea
Enviado el: martes, 11 de enero de 2011 09:05 p.m.
Para: rebel-builders@dcsol.com
Asunto: Re: [rebel-builders] Moose/Super Rebel brake issue
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
__________ Informaci
Jerald Folkerts
Post by Jerald Folkerts » Sun Feb 19, 2012 8:34 pm
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Eric
Fogelin
Sent: Wednesday, January 12, 2011 12:16 AM
002_large.html
problems to date.
N645E
Waltman
G. O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Jerald Folkerts
Eric,
Thanks for the link. Im working on a Super Rebel SR2500 and in
looking at your construction photos of the stabilizer -- it's exactly as the
SR 2500. Your concise documentation will be very helpful to me as I move
forward.
Fogelin
002_large.html
problems to date.
N645E
Waltman
G. O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
Jason Beall
Post by Jason Beall » Sun Feb 19, 2012 8:34 pm
I was able to lock my pedals up mounted on my floor panel while it was still on the work bench! I just disabled the dual system. I figure I can always add a second set of master cylinders at a later date on the co-pilots side.
-Jason
--- On Tue, 1/11/11, Ted Waltman <ted@vafm.org> wrote:
[quote]From: Ted Waltman <ted@vafm.org>
Date: Tuesday, January 11, 2011, 5:24 PM
over-center issue.
montanafloat
Post by montanafloat » Sun Feb 19, 2012 8:34 pm
The issue with the dual brakes is a adjustment problem not really a design
issue.
What causes it is the slave link from the petal to the horizontal shaft. If
the slave rod conector ( the ears that the slave link connects to ) on
either side on the horizontal rudder shaft becomes vertical with full rudder
and brake applied, it can go over center instead of returning to its
original position and you will have full rudder and no way to get it back,
also you will have no brake.
The adjustment on the rudder and brake petals takes some fine tuning on the
ajustments to get rudder and brake travel correct with out the danger of
going over center.
As I have said before I don't normally add to these threads but I have had
2 airplanes (Mooses) do this and feel it is something to be aware of.
Fortunately both of them were on the ground and the problem was discovered
before flight.
Keith Kinden
_____
G. O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
_____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1191 / Virus Database: 1435/3375 - Release Date: 01/12/11
rebflyer
Post by rebflyer » Sun Feb 19, 2012 8:34 pm
Hey Keith!
Nice to hear from you! I've missed seeing you and your family at OSH the last couple of years. I hope all is well.
Curt Martin
Sent: Wed, Jan 12, 2011 12:38 pm
ssue.
oing over center.
efore flight.
Keith Kinden
_____
. O'Shea
rom: "Bill Maxwell" <wrmaxwell@bigpond.com>
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
_____
rebflyer
Post by rebflyer » Sun Feb 19, 2012 8:35 pm
Hi Keith,
Rebflyer@aol.com
Curt Martin
Sent: Fri, Jan 14, 2011 4:15 pm
Hi Kurt
Give me a email address for you.
Keith
_____
ebflyer@aol.com
ent: Wednesday, January 12, 2011 5:17 PM
Hey Keith!
Curt Martin
rom: montanafloat <keith@montanafloat.com>
sue.
ing over center.
fore flight.
eith Kinden
_____
O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
_____
_____
Nancy
Post by Nancy » Sun Feb 19, 2012 8:35 pm
Keith, how you doing ?
Hope everything is fantastic in the new year for you.
Nancy
Sent: Friday, January 14, 2011 1:15 PM
Hi Kurt
Keith
_____
rebflyer@aol.com
Sent: Wednesday, January 12, 2011 5:17 PM
Hey Keith!
Curt Martin
ssue.
If
rudder
oing over center.
efore flight.
Keith Kinden
_____
. O'Shea
Bill
hi Tom and Ted
centering
Roger K
-> Tom,
can,
full brake
pedals
able to
pedal.
plane and
cutting
-> the pilot's leg.
cylinders or
brake
working
-> Ted
safety
like to
-> Thanks,
-> Tom Tonner
-> > Hello Rick,
Denver
-> area.
Cruise is
is full
confirmed
maybe 60
times
-> expensive
new one
more
of the
bar
right-side
right-side
-> brakes
-> > at all.
-> > Ted
Of Rick
-> > Byers
-> > Hi All,
ago,
building
M14-P
-> or
-> > O-540 engine.
Firewall
-> will
O-540's
-> and
peculiarities of
-> the
Engines for
performance
advertised
elevation is
-> 4780
in the
is where
locked
-> up.
posts by
standard
-> > Thank you.
-> > Rick Byers
-> > Hereford, AZ
_____
_____
