[rebel-builders] FUS 25 & 26
Post by Drew Dalgleish » Sun Feb 19, 2012 8:34 pm
I had to replace the skin under the door with .032 and the doorsill with
about .040 after I made wrinkles in both sides during 2 different hard
landing events while on wheels. I also replaced the glareshield with .032
because it wrinkled at the corners of the panel. I also added doublers at
the panel corners after the fact but I believe if you did it while building
that is all that would be needed.
At 06:38 PM 04/01/2011 -0800, you wrote:
I have some questions about the door area on the Rebel. I am just starting
on my interior fittings and flooring. Looking through the pictures and
archives it is evident that the fus 25 area needs thicker skin and doorsill.
Is it necessary to replace fus 26 as well? How many have failed in the
door area? Were they on wheels or floats? Since there are several hundred
rivets to drill out on each side to replace fus 26 as well as the lower
angle I do not want to replace them if it is not necessary but will if it
is. What is the best thickness to use? My goal is to keep moving forward
but seem to keep having to undo the original to beef it up.
If you guys could give me some good advice from your experience I would
appreciate it greatly.
Curtis
175R
Curtis Langholz
Post by Curtis Langholz » Sun Feb 19, 2012 8:34 pm
Drew,
Thank You for the information. I originally doubled the lower doorsill area but replacing the whole lower and angled doorsill with .032 as well as both skins would be much stronger.
I thought of making the doorsill on the outside about 2" deeper with an L to reach where the bulkheads have the notch in them just below the doorsill to strengthen that area. Do you think that is an overkill?
I did the 3" mod to the boot cowl. On the lower panel supports I had to make .032 corner braces to rivet the panel supports to since the angle of the side panels was shallower. Putting upper corner doublers is great advice! The glareshield is cut back and riveted in place with an extention for the windshield, the panel is only clecoe'd in place right now. I will make some doublers for the corners.
Also I noticed in the plans there is nothing about a doubler at the strut attach area where it goes through the skins. Shouldn't this have a doubler?
Thanks again,
Curtis
Date: Wed, 5 Jan 2011 18:38:07 -0500
Subject: Re: [rebel-builders] FUS 25 & 26
Curtis
175R
Post by Bob Patterson » Sun Feb 19, 2012 8:34 pm
Hi Curtis !
One of the Ontario mods. is to replace the ST-31 door frames
with ST-28 (.025), and another is to replace FUS-25 & 26 with
.032 or .040, plus add an extra vertical channel or 2 behind them -
either ST-31 or pieces of wing stringer.
Some builders have just overlayed a second FUS-25 & 26 over
the originals, slathering lots of epoxy primer in between. You
can do this if you drill oversize holes to clear the existing rivets,
then add new ones in between for the second layer.
The important one is the FUS-30 doubler for the lower
aft fuselage - pics in the Archives.... A lot easier to do these
while building....
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
responsibility of the reader.
doorsill. Is it necessary to replace fus 26 as well? How many have failed
in the door area? Were they on wheels or floats? Since there are several
hundred rivets to drill out on each side to replace fus 26 as well as the
lower angle I do not want to replace them if it is not necessary but will
if it is. What is the best thickness to use? My goal is to keep moving
forward but seem to keep having to undo the original to beef it up. If you
Curtis
175R
Curtis Langholz
Bob,
I purchased some .025 & .032 6061-T6 from ACS for the mods. I do not have any ST-28 or ST-31 channel left so was planning on making my own out of .032 for the doorsills.
For the FUS-30 doubler my plan was to only have to drill out the rivets in the FUS-36 bulkhead and the vertical stabilizer. The top row of rivets in the FUS-30 are countersunk so I plan on leaving those in place and drill new holes for the doubler between them so everything will stay in place.
You are right about it being easier to do while building. It is 3 times the work doing it over, plus it really slows the building process down!
If these areas have problems why is it that Murphy does not have any of these mods on their Tech Support page?
Curtis
Date: Wed, 5 Jan 2011 19:10:45 -0500
Hi Curtis !
while building....
bobp@prosumers.ca
bobp@pattersys.com
Curtis
175R
snowyrvr
Post by snowyrvr » Sun Feb 19, 2012 8:34 pm
Hi Curtis,
I made my FUS 26 out of .040 and bent a corner into it as you described, riveting it onto the floor on the underside. I think the bend will give it strength and it also looks cleaner than the corner piece the manual calls for. .040 might be overkill but I also have the gull wing door angle there so I just made it all one piece. Here's the web address for this photo on my site if you want to take a look.
http://alaskanrebel.com/coppermine/disp ... m=9&pos=32
Hope this helps. Craig
--- c120pilot@hotmail.com wrote:
To: REBEL BUILDERS <rebel-builders@dcsol.com>
Subject: RE: [rebel-builders] FUS 25 & 26
Date: Wed, 5 Jan 2011 16:06:25 -0800
Drew,
Thanks again,
Curtis
Curtis
175R
Curtis Langholz
Craig,
Glad to see someone has done it already so I know how it will look and work.
Great pictures of your plane, they helped a lot! Would you contact me directly? I have some questions about your doors.
Thank You,
Curtis
175R
Date: Wed, 5 Jan 2011 18:38:09 -0800
Hi Curtis,
Drew,
Thanks again,
Curtis
Curtis
175R
snowyrvr
Hi Curtis,
Here's my cell. If you'd like, give me a call tomorrow afternoon, Alaska time. Craig
907-355-6290
Date: Wed, 5 Jan 2011 19:22:13 -0800
Craig,
Thank You,
Curtis
175R
Hi Curtis,
Drew,
Thanks again,
Curtis
Curtis
175R
I think making the doorsill a bit longer like you suggest would be a great
idea. Easy to do for a lot of extra strength without adding much weight. I
made doublers for the strut area when I built my plane. It would be a pain
to have to repair cracks in the skin there.
At 04:06 PM 05/01/2011 -0800, you wrote:
Drew,
doubler?
Thanks again,
Curtis
