FUS 25 & 26
Curtis Langholz
FUS 25 & 26
Post by Curtis Langholz » Sun Feb 19, 2012 8:34 pm
I have some questions about the door area on the Rebel. I am just starting on my interior fittings and flooring. Looking through the pictures and archives it is evident that the fus 25 area needs thicker skin and doorsill.
Is it necessary to replace fus 26 as well? How many have failed in the door area? Were they on wheels or floats? Since there are several hundred rivets to drill out on each side to replace fus 26 as well as the lower angle I do not want to replace them if it is not necessary but will if it is. What is the best thickness to use? My goal is to keep moving forward but seem to keep having to undo the original to beef it up.
If you guys could give me some good advice from your experience I would appreciate it greatly.
Curtis
175R
