baffle sealing
Jesse Jenks
baffle sealing
Post by Jesse Jenks » Sun Feb 19, 2012 8:06 pm
I'm fitting the Vans baffles and wondering if I need to use something like RTV in the areas where the baffles meet the cooling fins and engine case to seal up all the small gaps. For example where the rear baffles sit on the back of the aft cylinders and around the cylinder attach studs/nuts.
This baffle kit is a great thing by the way...probably saves weeks of work and despair if you tried to do it from scratch. It must be cool to have a cnc machine.
Thanks.
Jesse
