[rebel-builders] 1800 floats-partial bulkhead.032 doubler
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:06 pm
I only make a flat "pie" plate and rivet it to the bulkhead.. I don't add a
bent flange to it. The only area I've seen crack is the area right above the
5/8 wide flat spot that you make to clear the keel strip.
Sent: Tuesday, November 09, 2010 9:39 PM
Subject: [rebel-builders] 1800 floats-partial bulkhead.032 doubler
wayne, thanks on the size details. is the flange at the bottom say along
each
3 inch side of the keel & riveted to bottom floor? rich
