[rebel-builders] Wheel Skiis
Post by Drew Dalgleish » Sun Feb 19, 2012 8:06 pm
At 05:57 PM 16/10/2010 -0700, you wrote:
Has anyone messed with building wheel or penetration skiis for our rebel?
If anyone could point me somewhere I would appreciate it. Thanks, Craig
I built a set of skiis that I shamelessly copied from the avid flyer
webpage. Avid is gone but I think you should still be able to google some
pictures. My origional mount had the skis hinged below the axle but this
week I drilled the ends of the axles for a 3/8"pin and have plans to
rebuild my skis a bit wider and hinge on ends of the axle. I also have
moved the die spring attach point up above the axle to expose the inboard
end.
snowyrvr
Post by snowyrvr » Sun Feb 19, 2012 8:06 pm
How about some photos, Drew? If you have any you can send them to snowyrvr@mtaonline.net
I was loking at the skiis on Wayne's site; I don't know if they are homemade or not but I liked them.
--- drewjan@cabletv.on.ca wrote:
Subject: Re: [rebel-builders] Wheel Skiis
Date: Wed, 27 Oct 2010 22:18:49 -0400
end.
Hi Craig I uploaded some pictures of my skis and what I have done to my
axles to the landing gear section in the files. I still have to widen my
skis and I don't know if what I've done will work or not. The origional
mounts worked well with my narrow wheels and 6:00-6 tires I have to try
something different in order to use my wide wheels and 8:00-6 tires.
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:06 pm
Yep.. they're "homemade"... my shop is beside the house! lol
Our hydraulics are $10,665 + attach fittings. Fixed penetrations, that I
built previously, I sold for about 1/2 that but don't have time in the
schedule to build a set for this coming season.
http://www.irishfield.on.ca/gallery/whe ... 20view.jpg
Sent: Wednesday, October 27, 2010 11:17 PM
end.
