sounds great, Ron. Drink a beer and send me the bill. You have earned it!
Question: Can you give us how many feet of runway you need to takeoff/land?
Tim Hickey
Montrose, Iowa
[rebel-builders] good to go
Thanks. I added an "s" and the bill's on the way. Beck's N.A., of course. ;)
Takeoff and landing are far from optimized by this pilot yet, but on
our paved strip, with first step (8 deg.) flaps -- or none with a
little wind -- it's easy to get off in 400 ft. I'm sure it would take
less if I tried, which I really haven't yet. (Although I've been
running the engine hard most of the time in the air for break-in, I've
tended to baby the takeoff throttle advance.) Even so, with just a
smooth power up from three point attitude, the mains are very light in
150 ft. or so, before there's enough elevator authority to lift the
tail! The VG's really work! :) No need to lift the tail where I've
been flying so far -- it's just a surprising data point. I usually
hold some ground effect for another 300-400 ft. before getting on the
escalator.
So far, it's been more like 700+ ft. to land and roll, especially with
our challenging approaches. I'm usually targeting 60 MPH indicated
"over the fence", however, landing west, the fence consists of a deep
wall of imposing 100+ ft. trees along the river, followed by a major
slip to get down through the lift created by wind rising over the tree
line. (A couple houses are underneath, about 1000 ft. out, when
landing east.)
I still have lots to learn, including more experience with full flaps.
It would be nice to get substantial flap drag for steep approaches and
then flick the switch to bring them up a notch or two to land, but I
haven't been there yet. We usually have enough wind that I'm more
comfortable landing with no flaps at all, and have done very little
slow flight even at altitude so far -- only a couple power on stalls,
before the VG's -- in deference to engine break-in.
Still lots to explore. The 40 hr. minimum is past, but test flying and
learning will continue.
Ron
escalator.
landing east.)
Ron
Tim Hickey
Montrose, Iowa
Congrats again, Ron. The numbers are very good indeed for that size engine
and plane. Keep at it with completing the little details. You should be in
great shape for some serious flying adventures by next summer. And don't
skimp on the paint job. That plane deserves a nice one.
Shannon
Sent: Friday, October 08, 2010 11:43 AM
Subject: [rebel-builders] good to go
Yesterday I finished 254R's 40-hour Phase 1 flight test period --
which means that henceforth, nowhere is safe from Rebellious invasion.
For those who may be interested, detailed performance data collected
to date is posted at http://n254mr.com/node/1607 As expected, the
calibrated & confirmed numbers are a little lower than the indicated
numbers reported in my exuberant "first flights" posting, but they're
still very good. Engine temps are all good and break-in is complete.
Significant mistakes I made early on include 1) not putting pedal pads
on the rudder/brake pedal tubing at the beginning, and 2) mounting the
brake cylinders to the pedals instead of the floor. Floor mounting of
the cylinders and proper pedal pads have made a ton of difference in
managing tailwheel steering and braking -- when they're needed most.
These things will be a big "duh" to many, but I was in a hurry to fly.
Also, in spite of what I thought was a well-founded conviction
everything had been exhaustively inspected, not only by me, but also
by other builders and our meticulous local EAA Tech Adviser, I still
found more than one alarming omission during the early preflight
inspections. I've always tried to be diligent about preflights, but
those experiences have really made me slow down, look, and think about
what the eyes are seeing even more. The preflight checklist has grown
to two single spaced pages. (The hard copy is all marked up with
corrections & additions right now, but I'll post a cleaned up version
soon.)
I still have lots of other things to do that were put off until after
first flights, like door locks, fairings, skylights, A/P servos, etc.
Numerous things have needed attention -- like wheel bearings that
loosened up, little oil leaks, door & window adjustments, frequent
wood prop bolt torque checks, etc. Even the spam cans need that kind
of thing -- maybe more of it.
The are only a couple drawbacks at this point. The AeroCarb throttle
body slide requires quite a bit of pressure to open throttle due to
engine suction pulling it down, with the friction augmented somewhat
by the unavoidably serpentine cable routing, both common problems. I'm
getting used to it, but still working on ways to reduce it. I also
still have some slow but persistent fuel seepage from rivets and seams
on both tanks. There are a couple more techniques to try before
cutting access ports to better seal them from the inside. A little
background whine has shown up in the 430W audio that I don't think was
there in the beginning. Still working on stabilizing the somewhat
erratic tach sender, though I've had excellent service from Advanced
Flight Systems.
With those few exceptions, which will be remedied in due course, I
couldn't be happier with the plane. It was quite a struggle to get it
done, but already the payback is huge. I feel very fortunate to have
been able to build the plane I wanted, and to now be flying it.
Ron
N254MR
Shannon
soon.)
Flight Systems.
Ron
N254MR
