[rebel-builders] Skis
Post by Drew Dalgleish » Sun Feb 19, 2012 8:05 pm
I've flown my rebel with fixed wheel skis and was always off in less than
500' solo. I never flew any where near gross so I don't know how much
difference that would make. I assume you have open aproaches and reasonably
level ground, landing over trees or downhill could make things a lot tougher.
At 09:43 PM 16/09/2010 -0800, you wrote:
Has anyone had there rebel on skis yet. Looking for some
performance data on skis. Mainly distance takeoff and
landing for STOL. I have about 900 feet and looking to see
if it is capable. Currently have rebel with o-235 120 hp. I
was getting it in at 400 feet on wheels.but not sure on skis.
Scott
scott_lanier
Post by scott_lanier » Sun Feb 19, 2012 8:05 pm
Thanks for the reply, i am not worried about getting off, but it is the getting
in and getting stopped that I am worried about. I am not a ski pilot yet, and
am not sure about landing and stopping.
On 9/17/2010 10:15 AM, drewjan@cabletv.on.ca wrote to rebel-builders:
-> I've flown my rebel with fixed wheel skis and was always off in less than
-> 500' solo. I never flew any where near gross so I don't know how much
-> difference that would make. I assume you have open aproaches and
reasonably
-> level ground, landing over trees or downhill could make things a lot tougher.
-> At 09:43 PM 16/09/2010 -0800, you wrote:
-> >Has anyone had there rebel on skis yet. Looking for some
-> >performance data on skis. Mainly distance takeoff and
-> >landing for STOL. I have about 900 feet and looking to see
-> >if it is capable. Currently have rebel with o-235 120 hp. I
-> >was getting it in at 400 feet on wheels.but not sure on skis.
-> >Thanks
-> >Scott
-> Drew
I've never had any trouble getting stopped in a few hundred feet with my
wheel skis but they're kinda draggy in the snow. Fresh snow slows you down
a lot faster than packed snowe does.
getting
reasonably
tougher.
-> >Thanks
-> >Scott
-> Drew
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:34 pm
Mike.. it depends on whether you want to play on hard packed strips and lake
ice or play in the deep stuff. I wouldn't put anything narrower, in a
straight ski, than 12" wide on a Rebel if you want to seriously play in the
snow.
The original Federal 1500 was only 6" wide and then went to 8".. 1800's 8 or
10" and 2000's 10 or 12". I put 12" wide bottoms on any 1500 beams I
rebuild. I have a pair of Aero 2000's here with the reinforced pedestal area
and 12" bottoms... already rigged for a Rebel if you are interested. Even
have some quick connect two wheel dollies to get from pavement to the snow.
Unfortunately we are snowed in here with over 2 feet of snow on the strip..
but I could do a change over at Midland in someone's hangar.
To: "Rebel Digest, " <rebel-builders-d@dcsol.com>
Sent: Sunday, December 19, 2010 7:17 PM
Subject: [rebel-builders] Skis
I thought I could get this info easily on the internet. How do you size
skis? It seems to me that there should be a direct relationship between
the gross weight of the aircraft and number of square feet or inches of
ski area. What you ski flyer putting on the Rebel?
Mike, C-FNBO
Post by Ken » Sun Feb 19, 2012 8:34 pm
Yes it is probably wise to go wide instead of long for skiis on a Rebel.
Less twisting leverage on the gear legs in turns.
snow.
Mike, C-FNBO
David Jackson
Post by David Jackson » Sun Feb 19, 2012 8:34 pm
No one has answered the original question. How much area of ski is required per pound of gross weight? Or to phrase it another way, if you do have 12 " wide skis for a Rebel, how long should they be?
Dave J
Date: Mon, 20 Dec 2010 06:43:50 -0500
Subject: Re: [rebel-builders] Skis
snow.
Mike, C-FNBO
Post by Drew Dalgleish » Sun Feb 19, 2012 8:34 pm
Dave J
I like Wayne's answer. It really does depend on the snow conditions you
expect to encounter. However there actually is a formula in ac43.13 scroll
down to chapter 5 for lots of info on selection and rigging for skis. When
I built my skis I just made them the same size as others that are
recommended for a plane about the same gross weight as a rebel. Mine are
12"x about 5'. Here's a link to ac43
http://rgl.faa.gov/Regulatory_and_Guida ... lar.nsf/0/
e533bb05389c90e486256a54006e47b2/$FILE/Chapter%201-8.pdf
I see that link wrapped around itself you can use this instead
http://tinyurl.com/29u84qo
Dave J
Post by Drew Dalgleish » Sun Feb 19, 2012 8:41 pm
I attached my front cables and bungees to the forward fus5 carrythrough
about 6" inboard from the door post. The rear cables go to the back gear
leg bolt. I considered using the rear float fitting for the back cable
but can't remember why I didn't use it. There's a chapter on ski rigging
in ac43.
On 18/02/2011 12:42 AM, scott_lanier@dcsol.com wrote:
Hello all,
I need some info for skis and the rebel. I have the skis and the rigging, but
need info on where guys are attaching the cables and bungies to the
fuselage. Any pics would be helpful. I need to see how and where you attach
thes to properly rig my skis.
Thanks and if you have picks of rebel on skis please forward to
scottrlanier@gmail.com
scott_lanier
Post by scott_lanier » Sun Feb 19, 2012 8:41 pm
Mine is on spring gear so not sure if yours is on bungee gear. Could you send
me a pic if possible?
Thanks Scott
On 2/19/2011 8:53 AM, drewjan@cabletv.on.ca wrote to rebel-builders:
-> I attached my front cables and bungees to the forward fus5 carrythrough
-> about 6" inboard from the door post. The rear cables go to the back gear
-> leg bolt. I considered using the rear float fitting for the back cable
-> but can't remember why I didn't use it. There's a chapter on ski rigging
-> in ac43.
-> On 18/02/2011 12:42 AM, scott_lanier@dcsol.com wrote:
-> > Hello all,
-> > I need some info for skis and the rebel. I have the skis and the rigging,
but
-> > need info on where guys are attaching the cables and bungies to the
-> > fuselage. Any pics would be helpful. I need to see how and where you
attach
-> > thes to properly rig my skis.
-> > Thanks and if you have picks of rebel on skis please forward to
-> > scottrlanier@gmail.com
drewjan
Post by drewjan » Sun Feb 19, 2012 8:41 pm
Mine is on bungee gear. I have some pictures that I think are in the archives. They don't show much detail though.
------Original Message------
Sender: mike.davis@dcsol.com
ReplyTo: rebel-builders@dcsol.com
Sent: Feb 19, 2011 1:53 PM
Thanks Scott
-> in ac43.
-> > Hello all,
but
attach
