fuselage end you can always anneal it by heating just the end to red hot
and letting it cool slowly. I would not do that to the tailwheel end though.
First I'd dry a carbide tipped concrete bit as per Dick's suggestion
(slow, hard pressure, oil) Don't be afraid to touch up the carbide a few
times if needed. I use a green grinding stone. Buy a couple of bits.
They are cheap.
There are also carbide twist drills but they are pricey. I've done this
sort of thing with hardware store cobalt bits but again be prepared to
sharpen it several times. When sharpening keep the cutting angle as
close to 90 degrees as you can.
I'm assuming you have access to a drill press. Drilling springs with a
hand drill would be rather difficult.
Dick Wampach wrote:
Oh, Oh! So did you try to drill a big hole all in one pass? Try a small
diameter carbide # 40 or so, slow turning, heavy pressure, cutting oil, &
don't side load the bit to break it. Good luck
Dick Wampach SR-108 N331RW
schaumr@dcsol.com
Sent: Monday, August 30, 2010 9:19 AM
Subject: [rebel-builders] Drilling through steel leaf springs:
work-hardening
Hi All,
Tried to drill through my steel tail spring this morning but managed to
render
half the hole "work-hardened" (not enough lube and/or cooling). What do I
do now? Carbide tipped bits? Other bits?
Hope someone can help me avoid buying a new tail spring!!
Rob
Rebel 786
password "builder"
