[rebel-builders] Lycoming 0-320 in storage
J Portman
Post by J Portman » Sun Feb 19, 2012 6:31 pm
The big thing is not really rust in the cylinders. It's rust on the CAM.
Any rust on the cam will shorten the life of the engine from thousands to
hundreds (maybe only dozens) of hours.
No way to tell if there is rust on the cam without cracking the case.
Just my two cents.
If the engine was built with all yellow tagged parts and got a "return to
service" form, then, if it was pickled properly, it might be OK.
It's a real roll of the dice, though.
If it were me, I'd buy it at a discount and have it disassembled, inspected
and reassembled before trusting it.
Just my two cents.
JP
On Tue, 10 Aug 2010 15:41:45 -0400, kriening wrote
Thought I would tap the vast amount of experience on this site and
get some opinions on the following.
I have come across a 0-320 E2A that was 0 timed by a professional
shop in 1999. The builder has it in storage since then and is now
selling it. The engine is being sold without accessories. The engine
was sealed for storage by the shop including a dehumidifying plug
at the time as the builder did not know how long the build would
take. The seller indicated to me... "The engine is
sealed....boroscoped last year by an A&P/IA and the result was that
it looked like it was overhauled yesterday. Everything still had
oil on it and no trace of a problem."
Not being an AME / AP, I am wondering what else I should be watching
for before the purchase. Any advice would be greatly appreciated.
Roland
R56
From: "Andrew Burr" <verticalperformance@yahoo.com>
Sent: Sunday, August 08, 2010 8:13 PM
Subject: Re: [rebel-builders] Fw: Fuel tank screen
Dave,
Thanks, so far I'm 8 hours in to cleaning the tank and still more to go. I
like to land at a lot of rivers were Avgas is unavailable but Mogas is.
Andrew E Burr XIV
Vertical performance LLc
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component
and holds ownership of all intellectual property for each component.
Date: Sunday, August 8, 2010, 11:48 PM
Hi Andrew
There's a lot of discussion in the mailing list archive about Pro-Seal,
Mogas and sloshing compound. I believe there are Proseal/Sealmaster
etc. compounds made especially for Mogas. Lots of discussion about
reasons to not use sloshing compound too.
You will probably find more info there than you will ever want to read
through ;-)
Elite583.cjb.net
Andrew Burr wrote:
Can any one tell me were to buy the fuel tank screen fittings. I'm in the
process of fixing my one fuel tank. One of the previous owners used tank
sloshing sealer on the tank and the screen is coated with the sealer.
Word of advise don't use tank sloshing sealant on your tanks. luckily
most of it is pealing off but what a mess. I also need to know if Pro
seal will hold up to car gas and ethanol. Some of the places I fly to
don't always have Avgas.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Checked by AVG - www.avg.com
Version: 8.5.441 / Virus Database: 271.1.1/3059 - Release Date: 08/08/10
17:57:00
Andrew Burr
Post by Andrew Burr » Sun Feb 19, 2012 6:31 pm
Roland,
I rebuild engines for a living and have seen a few engines in over 20years.
If the engine was pickled right and kept in a climate controlled building it might be ok.
A freshly rebuilt engine that has been sitting is worse than an old engine that has been running before stored. The cam and lifters take the most abuse when an engine is stored.
If it was me I would crack it open and go through it. You will do more damage if you start it up with corrosion on the cam and lifters which will cost more to fix than just going through it.
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
VPHelo, LLc has paid for the design and engineering for every component and holds ownership of all intellectual property for each component.
--- On Tue, 8/10/10, kriening@rogers.com <kriening@rogers.com> wrote:
Subject: [rebel-builders] Lycoming 0-320 in storage
Date: Tuesday, August 10, 2010, 7:41 PM
Thought I would tap the vast amount of experience on this site and get some
I have come across a 0-320 E2A that was 0 timed by a professional shop in
1999. The builder has it in storage since then and is now selling it. The
engine is being sold without accessories. The engine was sealed
karl hipp
Post by karl hipp » Sun Feb 19, 2012 6:31 pm
Ya don't need to crack the case to look at the cam--just pull a jug--I
suggest # 2 or # 3 as I think you can see more of the cam. Pull em all
if you wanna see the entire cam. Not a big deal at all
Karl Hipp
Just my two cents.
Just my two cents.
JP
Roland
R56
Dave,
Andrew E Burr XIV
Po Box 213
Cassville MO 65625
Hi Andrew
through ;-)
Elite583.cjb.net
