Yes, they told me to use 1 1/2 inch spacing on the stabs instead of 3 inches
as on the wings.
allen.hewko@dcsol.com
Sent: Tuesday, July 20, 2010 8:02 PM
Subject: [rebel-builders] RE: vg's on elevator
The land shorter vg's need the slight curve sanded flat so they stay glued
the stab. I used a bench mounted belt sander, it doesn't take much to get
them flat. They should have came with a pattern for the stab, it is a closer
spacing than on the wings. After putting the vg's on the wings I had to put
set on the stab to get more elevator at slow speeds, but I still don't seem
have quite enough. I am quite happy with the better performance and control
I got with the land shorter vg's.
Allen
C-FXNS
On 7/18/2010 6:11 PM, wright.garry30@gmail.com wrote to rebel-builders:
-> Looking for experience with vg's on the elevator for rebels. I have the
-> landshorter set and I guess the major question is, does anyone have
-> experience with these on the elevator and what spacing from the hinge
-> was most effective?
-> Garry
-> C-FOKM
Did you try different spacings forward of the hinge on the elevator?
Garry
Garry
closer
Allen
C-FXNS
-> Garry
-> C-FOKM
No,
I just went with the recommended spacings and placement.
The stab vg's are harder to put on and keep glued on, I just found a nice
grassy spot to lay on my back to install them.
Allen
On 7/20/2010 8:10 PM, wright.garry30@gmail.com wrote to rebel-builders:
-> Did you try different spacings forward of the hinge on the elevator?
-> Garry
-> On Tue, Jul 20, 2010 at 9:02 PM, <allen.hewko@dcsol.com> wrote:
-> > The land shorter vg's need the slight curve sanded flat so they stay
glued
-> > to
-> > the stab. I used a bench mounted belt sander, it doesn't take much to
get
-> > them flat. They should have came with a pattern for the stab, it is a
-> > closer
-> > spacing than on the wings. After putting the vg's on the wings I had to
put
-> > a
-> > set on the stab to get more elevator at slow speeds, but I still don't
seem
-> > to
-> > have quite enough. I am quite happy with the better performance and
control
-> > I got with the land shorter vg's.
-> > Allen
-> > C-FXNS
-> > On 7/18/2010 6:11 PM, wright.garry30@gmail.com wrote to rebel-
builders:
-> > -> Looking for experience with vg's on the elevator for rebels. I have
-> > -> landshorter set and I guess the major question is, does anyone have
-> > -> experience with these on the elevator and what spacing from the
hinge
-> > -> was most effective?
-> > -> Garry
-> > -> C-FOKM
Allen
-> Garry
glued
-> > to
get
-> > closer
put
-> > a
seem
-> > to
control
-> > Allen
-> > C-FXNS
builders:
hinge
-> > -> Garry
-> > -> C-FOKM
Thanks Allen and Walter. I will take the elevators off and glue them on at
1.5" spacings as close to the hinge line as possible. That comes after I get
the floats to quit leaking.
G
G
No,
Allen
-> Garry
glued
-> > to
get
-> > closer
put
-> > a
seem
-> > to
control
-> > Allen
-> > C-FXNS
builders:
hinge
-> > -> Garry
-> > -> C-FOKM
Garry, you might want to give Harrison a call and see what he says. I am not
sure about how close to the hinge line they should be. I would try with the
double sided carpet tape in a couple positions to see what happens.
Eric, didn't you put them on your stabs?
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Garry
Wright
Sent: Wednesday, July 21, 2010 6:38 PM
Subject: Re: [rebel-builders] RE: vg's on elevator
G
Wright
G
don'tNo,
Allen
-> Garry
glued
-> > to
get
-> > closer
put
-> > a
haveseem
-> > to
control
-> > Allen
-> > C-FXNS
builders:
havethe
hinge
-> > -> Garry
-> > -> C-FOKM
Hi Garry !
The VG's usually go on the bottom of the stab, about
an inch ahead of the hinge line .... not on the elevators ! ;-)
....and definitely NOT on TOP of the stab - I did the test
flying on a Rebel years ago that had them on top - just a
mistake .... might have helped with outside loops though ! ;-)
We're in a motel in Michigan City - about 65 miles east of
Chicago - hope to hit OSH tomorrow (Thursday) afternoon late ...
maybe in time for supper at Friar Tuck's !! :-) :-)
See everybody at the Moose !
......bobp & Anna
bobp@prosumers.ca
responsibility of the reader.
......bobp & Anna
bobp@prosumers.ca
get the floats to quit leaking.
G
On Wed, Jul 21, 2010 at 7:15 PM, <allen.hewko@dcsol.com> wrote:No,
Allen
-> Garry
glued
-> > to
to get
a -> > closer
put
-> > a
don't seem
-> > to
control
-> > Allen
-> > C-FXNS
builders:
have the
have -> > -> experience with these on the elevator and what spacing from
the hinge
-> > -> Garry
-> > -> C-FOKM
Thanks Bob. Enjoy OSH.
G
On Wed, Jul 21, 2010 at 10:27 PM, Bob Patterson (e) <bobp@prosumers.ca>wrote:
G
Hi Garry !
......bobp & Anna
bobp@prosumers.ca
On July 21, 2010 09:37:54 pm Garry Wright wrote:atThanks Allen and Walter. I will take the elevators off and glue them onnice1.5" spacings as close to the hinge line as possible. That comes after I
G
The stab vg's are harder to put on and keep glued on, I just found arebel-builders:grassy spot to lay on my back to install them.
Allen
On 7/20/2010 8:10 PM, wright.garry30@gmail.com wrote tostay-> Did you try different spacings forward of the hinge on the elevator?
-> Garry
-> > The land shorter vg's need the slight curve sanded flat so theyisglued
-> > to
to get
-> > them flat. They should have came with a pattern for the stab, ithada -> > closer
-> > spacing than on the wings. After putting the vg's on the wings Iandto
put
-> > a
don't seem
-> > to
-> > have quite enough. I am quite happy with the better performancefromcontrol
-> > Allen
-> > C-FXNS
builders:
have the
have -> > -> experience with these on the elevator and what spacingthe hinge
-> > -> Garry
-> > -> C-FOKM
