float stiffeners
Curtis Langholz
float stiffeners
Post by Curtis Langholz » Sun Feb 19, 2012 6:24 pm
Nig,
Thanks for the reply. I have my boot cowl and firewall completed with the original .020 upper wraps. I have seen a Rebel with the upper motor mount doubler going all the way to the door post, that may be another option for me at this point. I did install the channel between the upper mounts per MAM. Do you know where I can get the specs or good pictures for the Ontario mods? I have spent some time looking through the archives but was unable to find the mods in archives, still searching.
Curtis
175R
Subject: RE: [rebel-builders] Up to date builders manual needed (Float stiffeners)
Date: Wed, 9 Jun 2010 12:25:31 +0100
Hi Curtis
The Firewall stiffeners are part of the "Ontario Mod's" that are highly
recommended - courtesy of Wayne I think.
I've fitted them to my Elite. One large section across the bottom and 2
smaller triangles at the upper motor mount attach points.
Other recommendations are stronger (thicker) corner wraps, and 2 under floor
stiffeners running from near the bottom motor mount points aft towards the
FUS-5 carrythrough. Pictures already in the archives I think.
Nig
745E
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
