Your following message has been delivered to the 172 members of
the list murphy-rebel@dcsol.com at 09:13:31 on 14 Dec 2000.
Bruce, there may only be one Rebel that MAM "claims" to know about, but
unless Darryl shred it he has a 3 or 4 page dissertation from me in his
files describing how I sheared EVERY rivet out of my passenger door post
(and the top 5 out of the pilots side) from the top all the way down to the
wing strut attach fitting (while flying on skis in 1996). Just like opening
up a can of sardines!! I tried to get the equivalent of the "float fix
bulletin" issued back then to no avail, and it didn't actually come about
until aircraft were damaged, in front of the "world", at Oshkosh!
My fix was (and still is) to drill for and install another staggered row
(mid point between the existing rivets and forward or rearward enough to
just catch the tube without hitting the outside wall) of stainless RR5404
rivets up the door post (carry through) with the top four original holes
being enlarged to #11 for 3/16 Stainless Rivets so the guillotine action
can't get started. This has held up so far on all the Rebels I have worked
on. If the windshield is already in place you can't really do the gusset
thing. If the windshield isn't already place, I would do the gusset plate as
this puts a nice size Band-Aid right were the shearing of rivets wants to
start. (The SR2500 has a huge plate/gusset put here).
FWIW, MOST "fixes" I offer to this list aren't theoretical folks! I have
been nice enough to bust up my aircraft for you (as have others like
Allister) to develop them so your's stays together!
Regards,
Sent: Thursday, December 14, 2000 12:47 AM
Subject: Re: witches hat install
theWayne,
How important are the gusset plates at the top of the front and rear door
post, on MAM float fix? The new manuals only show the 2" channel between
G.,engine mounts, but the SB show the channel "and" the gusset plates. Brian
postat MAM, told me only one Rebel on floats ever had a problem at the door
*---------------------------------------------------------------------------and it was landing in to rough of water.
Bruce G 357R
*---------------------------------------------------------------------------Contributors' page at:
Visit the book store at:
