[rebel-builders] ground handle
Gary Gustafson
Post by Gary Gustafson » Sun Feb 19, 2012 6:23 pm
The brackets once riveted hold the through rod in place. Can not
remember if I had to put in a set screw or not. Then the handle
extensions pop out once the insert if pushed in and twisted. Works
well and is very handy.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
R. Greaton
Sent: Friday, May 14, 2010 10:23 AM
To: rebel builbers list
Subject: [rebel-builders] ground handle
I have the murphy ground handeling handle.
What holds the through rod in place once the brackets are installed. There
is no place for a set screw or such?
Dave Greaton
Moose 189 Maine
