Most pitot tubes I've seen on Moose are near the joint of wing/wingtip and
on the L wing.
William Taft
Sent: Tuesday, April 06, 2010 10:15 AM
To: rebel-builders
Subject: [rebel-builders] Pitot tube on a SR 2500
Can any one give me suggestions as to placement on the wing for the pitot
tube?
How far out, how far back, as well as any other information in this area.
This is for a SR 2500.
William Taft
Mine is placed in the same wing bay as the aileron push / pull tube, a few
inches inboard of the access hole in the bottom of the leading edge skin. I
added a doubler on the inside installed with flush rivets. Mine is the new
Dynon heated AOA Probe. Static ports are located between fire wall and
front door posts.
Dick Wampach SR-108 N331RW
Waltman
Sent: Tuesday, April 06, 2010 11:15 AM
Subject: RE: [rebel-builders] Pitot tube on a SR 2500
on the L wing.
William Taft
To: rebel-builders
tube? How far out, how far back, as well as any other information in this
area. This is for a SR 2500. Thanks William Taft
password "builder"
password "builder"
front door posts.
Waltman
on the L wing.
William Taft
To: rebel-builders
password "builder"
password "builder"
