[rebel-builders] Aircraft rigging
Post by Wayne G. O'Shea » Sun Feb 19, 2012 6:19 pm
If the rudder trim is bent to the right.. pushing rudder to left... it is
adding to your left turn tendency.. not helping it!
Sent: Monday, April 05, 2010 12:13 AM
Subject: [rebel-builders] Aircraft rigging
Need some help for rigging the Rebel....
My left aileron needs to be 1" low and right aileron needs to be 1" high
in order to level the wings (left wing heavy). The rudder trim is offset
to the right, which would push the rudder to the left a little bit in
order to fly straight.
Any Rebel/Elite pilot has similar issues can share your wisdom with me?
I'm not the builder, I went through the installation manual, didn't see it
anywhere mention "aircraft rigging", where are the documentation?
Jay
Hotmail has tools for the New Busy. Search, chat and e-mail from your
inbox.
http://www.windowslive.com/campaign/the ... P:042010_1
..also.. other things to try to help you! Engine.. lyco/rotax.. or a
backwards turning auto conversion?
Is the fin mounted straight.. or is it offset.. how much. and which way if
so?
Sent: Monday, April 05, 2010 12:26 AM
Subject: Re: [rebel-builders] Aircraft rigging
it
Jay
inbox.
Jay Yau
Post by Jay Yau » Sun Feb 19, 2012 6:19 pm
that's the only way I can maintain the heading ---straight. Am I doing it wrong?
Jay
Date: Mon, 5 Apr 2010 00:26:35 -0400
Jay
inbox.
The New Busy is not the old busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_3
Jay Yau
Hi Wayne,
I have O-320 B2A, 160 Hp.
Jay
Date: Mon, 5 Apr 2010 00:45:48 -0400
so?
it
Jay
inbox.
Hotmail is redefining busy with tools for the New Busy. Get more from your inbox.
http://www.windowslive.com/campaign/the ... P:042010_2
Jay Yau
Hi Wayne,
If I remember right, the ball was a little bit to the left, that's why I bent the rudder trim a little bit to the right to give a slightly left rudder to bring the ball back to the center. Does this contribute to left wing heavy?
Jay
Jay
inbox.
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox.
Jay Yau
The fin looks pretty straight to me.
Jay
Subject: RE: [rebel-builders] Aircraft rigging
Date: Sun, 4 Apr 2010 21:54:27 -0700
Hi Wayne,
Jay
so?
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_4
Post by Walter Klatt » Sun Feb 19, 2012 6:19 pm
Are you flying in reflex or in neutral flaperon setting when your left wing
is heavy? With my Rebel, it is totally hands off in reflex (which is what
you want), but in neutral it is slightly heavy on one side, too (can't
remember which side, though). I don't know why there is a difference, but
there is.
I have no rudder trim tab on mine, but my fin is offset by 3/4 inch as per
manual. In cruise, it is neutral, but in climb, I need to push some right
rudder, which is what you would expect.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jay
Yau
Sent: Monday, April 05, 2010 12:45 PM
Any Murphy builder out there has answers for rigging the Rebel?
My left wing is heavy when flying solo, I'm 150lbs, both fuel tank equal,
with lycoming engine O-320 160hp.
In order to keep the wings level, I had to trim the Aileron so left aileron
is 1" down and right aileron 1" up, and a little bit of left rudder to keep
the nose straight (ball in the center), where could be the problem?
If I neutralize everything and start from fresh un-rigged condition, do I
trim the rudder first or Aileron first?
Jay
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with
Hotmail.
http://www.windowslive.com/campaign/the ... ocid=PID28
326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5
Jay Yau
Walter,
Appreciated for your reply.
My situation is like yours, when I'm cruising with flaperon on reflex, with the current trim, I could fly hands free.
The left wing will become heavier when the flaperon set to neutral or 2,3 notch, the rudder is trimmed to have slightly left rudder input, otherwise the nose will move to the right (during cruise).
So, if I'm on Neutral or higher notch flaperon, the stick needs to move 1" to the right to pick the heavy left wing. (left aileron is 1" down and right Aileron is 1" up).
During climb out, my Rebel always requires right rudder to counter balance the slip stream and P-factor. 160HP is pretty powerful for a 950 lb airplane.
Can you look at both of your ailerons next time when you cruise with flaperon neutral ?
Jay
Date: Mon, 5 Apr 2010 13:03:31 -0700
there is.
Yau
Jay
Hotmail.
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail.
http://www.windowslive.com/campaign/the ... P:042010_5
Post by Bob Patterson » Sun Feb 19, 2012 6:19 pm
Hi Jay !
This is a very common problem ... if you have the original fiberglass
wingtips, there's a good chance one is lower than the other.
Easy fix is remove or straighten all other tabs, then cut a piece
of Lexan about 3 or 4" wide, by about 2 inches. Bend the rear 1"
down about 1/8" to start, and fasten it to the rear of the left tip,
with the wider direction parallel to the wing span. (4" wide x 1" down)
Be sure to round all corners of the tab, so you can't injure anyone
with it, right near eye level. Test fly, and bend down more if necessary.
Walter is right, you should be neutral with 2 notches of reflex flapperon.
With the O-320, you should have 2 notches of negative - drill an extra hole !
For easier trim . I usually wrap a piece of bungee cord around the left
stick a couple of turns, and hook it to the tube at the right stick base.
To adjust aileron trim, just slide the bungee up or down the stick !
Gliders did this for years ... for elevator trim too ...
bobp@prosumers.ca
responsibility of the reader.
keep the nose straight (ball in the center), where could be the problem?
Jay
Jay Yau
Bob,
So wonderful to hear from you, and thank you for sharing your wisdom with me.
I'm not sure if my fiberglass wingtip is "original" (I didn't build her), if I understand correctly, the Mod is to add more surface area and lift to heavier wing, am I correct? But I still don't understand how could it be "fastened" to the rear of wingtip, do I need to rivet in the wing tip fiberglass? My wingtip is riveted to the wing.
The bungee stick trim is brilliant, I use the same method to secure my flap control handle, the builder had built in a way that if could pop lose during landing (never happened but has that potential)
I'll modify and add the 2nd notch of reflex (negative flaps) if the control plate has room for extra, I remember it has pretty much reached the front already.
I may fly Rebel to Oshkosh this year.
Jay
Date: Mon, 5 Apr 2010 16:56:10 -0400
Hi Jay !
bobp@prosumers.ca
Jay
Hi Jay !
Yes, you can rivet the piece of Lexan to the tip, or maybe use
self-tapping screws until you get the angle right ...
Sounds like just the bungee might do the trick ...
The extra notch of reflex should give another 3 mph cruise ...
If you fly to OSH, maybe you can park in central Homebuilt Camping.
We hope to have 2 Moose there for a non-stop Murphy Party ! :-)
We leave in the morning for Sun 'n Fun - big Murphy Builders Party
is Tuesday, April 13th, starting at 4 PM in the Campground Corn Roast
area. Everybody welcome !! Hope to see you all there !
bobp@prosumers.ca
On April 5, 2010 05:33:08 pm Jay Yau wrote:
Bob,
me.
already.
Jay
Hi Jay !
flapperon. With the O-320, you should have 2 notches of negative - drill
an extra hole !
equal, with lycoming engine O-320 160hp.
aileron is 1" down and right aileron 1" up, and a little bit of left
rudder to keep the nose straight (ball in the center), where could be
the problem?
I trim the rudder first or Aileron first?
Jay
