hardware to me. A 2.45" panel hole would be correct for that if the
bottom connection port works for you and you devise a method to fasten
it to the panel. There is also archival discussion of that.
As per recent post I picked up the same gauge from Northern Hydraulics
with a rear mount (rear connection port) complete with panel mounting
hardware for about $10.
I would prefer a smaller gauge in case I ever want to replace it with a
2.25" standard instrument so I still have not cut the hole or decided
whether to use one of these.
craig wrote:
Does anyone have a hydraulic pressure gauge from their float kit
lying around? I'm planning for the future and need to put a hole in
my dash. Craig
