[rebel-builders] Angle of incidence 818R
Post by Ken » Sun Feb 19, 2012 6:15 pm
I would not recommend this. Think you will find that reflexed Rebel
flaperons are a better solution. One thing the Rebel does not need is
more nose up attitude from what I can see. It would also complicate
fairings and reduce take off performance on floats. OTOH I did lower the
leading edge of the stab as per Wayne's post of some years ago and am
glad that I did.
You may find the answer to your incidence question in some of the float
rigging messages as the incidence relative to the bottom of the fuselage
has been mentioned several times as has the angle between the bottom of
the wing and the bottom of the fuselage.
mikeh@dcsol.com wrote:
Hi all,
I've been wondering why the 320 Elite cruises faster than the 320
Rebel...... if it does. I've just re-read Darryls letter on the net about
moving the firewall back 3" where he says the angle of incidence of the
Rebel is greater than the Elite because the Elite is expected to cruise
faster than the Rebel because the 360 can be fitted.
I'm building a 320 Rebel and am thinking my cruise might increase if I
use the Elite a of incidence.
Can anyone advise me of the angles of incidence of both planes? And
has anyone made a comparison?
Thanks and Cheers Mike
Post by Walter Klatt » Sun Feb 19, 2012 6:15 pm
Can't say if the angle of incidence of the wing matters, but have not seen
an Elite that can go faster than my Rebel,... yet. Dennis is installing his
new O-375 now, so that might be the first one. But we'll see...
I think fairings have the biggest effect on speed, including amphibs, based
on the experience of Steve Sloan down in Arlington. And yes, flaperon reflex
really speeds it up, too.
I recently changed my float angle from 2.5 to 3.5 degrees. Have not noticed
any difference in speed or any nose down pressure.
Sent: Sunday, March 21, 2010 2:21 PM
Subject: Re: [rebel-builders] Angle of incidence 818R
glad that I did.
Hi all,
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 6:15 pm
Just so folks know, please don't create spaces as in the above Subject line,
in your emails. My anti-virus program, for instance, flags it as a
suspicious email. If my program flags it, then surely other anti-virus
programs will too. Keep your Subject "together"...
Klatt
Sent: Sunday, March 21, 2010 7:17 PM
Subject: RE: [rebel-builders] Angle of incidence 818R
glad that I did.
Hi all,
Can't remember what exactly he did there, but am sure Steve Sloan faired
that area as well. Yeah, I took care of mine with the bigger engine... <g>.
mikeh@dcsol.com
Sent: Tuesday, March 23, 2010 2:49 AM
Subject: [rebel-builders] Angle of incidence 818R
Thanks Ken and Walter for your input. I'll do some searches in the archives
re float stuff and stabilizers. Speaking of fairings, has anyone come up
with anything to fair the stabilizer strut/tailspring area of the Rebel? It
looks a bit draggy to me, and a bit complicated. Or doesn't it matter? Or
do I just fit a bigger engine Walter?
Cheers and thanks Mike
