Seems like a comfortable height, and the crawling around inside wont last
forever.
On another note, I have piece of rolled .20 skin that appears to be for the
back of the tailcone but it is labeled fus 413. Havent come across that in
the instructions yet. Is it a doubler for the back? I have two fus 29s for
the end of the tailcone, so not quite sure where this fus 413 goes.
Roland
R56
G. O'Shea
Sent: Sunday, March 14, 2010 10:57 AM
Subject: Re: [rebel-builders] Work table height
Heck... I thought you would have used Bountiful kegs Nig !
Sent: Sunday, March 14, 2010 7:11 AM
Subject: RE: [rebel-builders] Work table height
Hi All
I supported my entire work table on milk crates. I think I started 4 deep
and it was great for doing all the smaller sub assemblies. When I started
the FUS build up I lowered the whole table to 3 crates to be able to reach
higher up the structure. Again I used extra crates to build a ramp around
the fin area.
Not sure if you guys have anything similar - maybe beer crates ?
Give me a call if need a hand to empty them :-)
Nig
745E
mikeh@dcsol.com
Sent: 14 March 2010 10:40
Subject: [rebel-builders] Work table height
Hi Roland,
FWIW my work table has been too low/too high for most of the build.
Having been working on the fuse for a while I have been using a short step
ladder sometimes and some plastic milk bottle crates which stack on top of
each other (not sure what is done over there with milk bottles) and are
about 18" high. Seems easier to adjust my height than the table. I do also
have another small bench at a comfortable height which I use to do the
jobs
that don't have to be done "in situe".
The milk bottle crate system failed once.......when I forgot I was at
level 2, and stepped off thinking I was only at level 1! Hasn't happened
since.
Cheers Mike
