[rebel-builders] signs of life- from 818R
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 6:14 pm
Hello Mike
Good to hear from you. It's been a while. Sounds like you are really moving
along. I don't know when you received your kit but it took me almost 2-1/2
years to get where you are.
I am still a long way from flying. Just finished installing the fuel lines
and shut off valves and about half way through making the doors and windows.
Accept for a couple large holes my firewall is ready to rivet in but thought
I would do as much wiring on the instrument panel as I can while the
firewall is out of the way. That's the plan but we have had a cold wet
winter and in a month or so will be busy cutting grass and working outside.
Charlie E. 802R
Sent: Wednesday, March 03, 2010 3:35 AM
Subject: [rebel-builders] signs of life- from 818R
Pleased to see some signs of life, I thought we had some sort of technical
fault. How is your project going Charlie? You must be getting close to
flying? I'm close to putting the top skin over the cabin and it's starting
to look like a plane at last.
Cheers Mike Holloway
