As you said there are 3 fitting coming out of tank wing root. The most Aft
fitting (large) is for fuel. The 2 forward fitting are used for fuel site
gauge, top fitting has a T-fitting, from there you can cross vent to the
other wing. Then front he bottom of the T fitting you will hook to the
lower front fitting, this allows you to have a fuel "sight" gauge.
Jeff
PS: Of course there are other ways to vent the tanks and also there are
other type of fuel sight guages to use.
On Sun, Feb 14, 2010 at 4:51 PM, Rick Muller <rick.h.muller@gmail.com>wrote:
I have been off-line for 2 years after moving to a new home... paint,
floors, etc. Gettiing back to building.
How have you routed fuel lines. There are 3 fittings exiting each tank.
The high one is for cross ventilation. How have others plumbed the lower
two ?
Rick Muller
Rick.H.Muller@gmail.com
