Dennis,
Wayne has mentioned his fix in the past. It should be archived. He suggests using brake line to fashion a tubular spacer on either side of the rod end ball. The spacer length is long enough to allow rotation for stop to stop (fore & aft) plus a smidgen for clearance.The spacer wall thickness has to be enough to withstand bolt compression and turning force but not so thick as become an interference.
As another option -which I am using - ACS has a part that allows rotation internally and is threaded in each end for the rod ends. No ACS catalog here at home and it is a little obscure to find but solves the threaded rotation.
control column rotation
Ralph,
Is this the part you have from ACS?
http://www.aircraftspruce.com/catalog/a ... earing.php
Rob
On 2/3/2010 9:04 AM, rebaker@sc.rr.com wrote to rebel-builders:
-> Dennis,
-> Wayne has mentioned his fix in the past. It should be archived. He
-> As another option -which I am using - ACS has a part that allows rotation
-> Ralph Baker
Rob
-> Dennis,
-> Ralph Baker
