[rebel-builders] Things that keep me awake at night.. Rebel
N.Smith
Post by N.Smith » Sun Feb 19, 2012 5:59 pm
Wayne, I used to be brunette before I started going gray :-)
Thanks for the heads up again.
Nig
745E
G. O'Shea
Sent: 30 January 2010 04:10
Subject: [rebel-builders] Things that keep me awake at night.. Rebel
As I pull the latest wreck apart.. some things just jump up and make me
wonder how long it would have taken for an inflight instead of a landing
incident. I also give thought to how many others might be out there with the
same conditions and I post to be sure nobody here is making the same errors
on their Rebel build.
Control column.. those two bearing bases get riveted in with 3/16" rivets..
RV-1613's.. not 1/8" x RV1410's.. and especially not when the carrythru's
have been cut in half and those rivets are into two layers of skin and not
the .125 FUS-5's !! Better yet if you have the full size FUS-5's.. drill and
tap the right side bearing base for AN3 bolts so you can easily remove the
column to work up under the panel.
The elevator push/pull tube's end plugs get riveted in with FOUR 1/8"
stainless steel rivets... not TWO !.. that goes for ALL the push pull tubes.
Cleco's are not used to hold structure together after the build is done.....
ANYWHERE. Count them in and out as you build, just like a surgeon is suppose
to do with his tools.
Okay.. now maybe I can sleep.. unless a good looking Brunette keeps me up
late.... ;O)
gleeso1
Post by gleeso1 » Sun Feb 19, 2012 5:59 pm
Hey Nig, I think you missed the "GOOD LOOKING " bit ;-)
John
Nig
745E
G. O'Shea
late.... ;O)
N.Smith
Careful John... we're getting off topic :-)
gleeso1
Sent: 30 January 2010 08:51
Subject: Re: [rebel-builders] Things that keep me awake at night.. Rebel
John
Nig
745E
G. O'Shea
errors
rivets..
tubes.
done.....
suppose
late.... ;O)
Post by Wayne G. O'Shea » Sun Feb 19, 2012 6:02 pm
Forgot to mention one... that it appears many people miss, as this is the
7th airplane I have found this on over the years!!
When you install the extra set of bulkheads, to install the float hard
points... remember that although it may not get mentioned in the manual ( I
didn't check).. you need to drill and rivet those bulkheads to the bottom
skin of the fuselage. It's not helping much if it's just left flapping
around in there !!
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Friday, January 29, 2010 11:09 PM
errors
rivets..
tubes.
done.....
suppose
late.... ;O)
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 6:02 pm
Hi Wayne,
FYI, it is mentioned in the build manual (at least the one I have). The
following is excerpt is taken from Murphy Aircraft Mfg Ltd Rebel build
manual.
*12.27 Float Attach Points (optional)*
*19) On the outside of the floor skin, mark a line along the center of the
new bulkhead flange. Drill, debur and rivet the bulkhead through the floor
at the same spacing as the other bulkheads.
20) Repeat for the side skins.*
I've seen the float bulkhead riveted to the floor, but not the
sides........... go figure !!
Jeff
On Tue, Feb 2, 2010 at 7:00 PM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
around in there !!
errors
rivets..
not
tubes.
done.....
suppose
late.... ;O)
