Elevator Adjustments
Dave Klimas
Post by Dave Klimas » Fri Feb 17, 2012 8:34 pm
Another, less obvious cause for a tightening of the elevator horn on
my installation was because the horizontal tail bulkhead FUS-31 has a
tendency to bow downward toward the center causing the delrin blocks
to tilt down when tightened. I added a length of aluminum angle
(side-to-side) across the top and in front of the elevator horn to
remove the bow.
Ramona, CA
<snip>
The trick was that after you
torqued the delrin blocks down, the horn tightened right up indicating that
the block was deforming as it was being tightened. And yes, I used a torque
wrench on the AN3 bolts. Quite a surprise. Just something to watch for.
Regards
Brian #328R
