[rebel-builders] Bell Crank Holder position
N.Smith
Post by N.Smith » Sun Feb 19, 2012 5:54 pm
Hi Roger
I've been setting mine up recently so have quite a bit of info. Are you
still on the same tel number as a few years ago?
Nig 745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Roger
Cole
Sent: 24 December 2009 02:39
To: Rebel Builders
Subject: [rebel-builders] Bell Crank Holder position
Can some of the Elite builders help clear up some confusion in the
instructions? Instruction 15.6.1 and Figure 15.6.1 show a 4 13/16-
inch dimension to position the Bell Crank Holder (CC-42). Later on,
in instruction 15.6.9 the Bell Crank Brace (CC-41) is centered on the
Bell Crank Holder. If I do that, the forward-most hole in the Bell
Crank Brace is left hanging in mid air forward of the cage
structure. Is the 4 13/16-inch dimension correct? Is there a
better way to position the Bell Crank holder?
Another point of confusion is whether the long arm of the Bell Crank
Assembly (CC-47-2) should point forward or the short arm should point
forward. The instructions don't say which is correct. Would the
Bell Crank Holder be aligned best if the hole in the forward end of
the Bell Crank is aligned with the centerline of the Torque Tube
(CC-35)?
Thanks in advance for your help.
Roger Cole
Murphy Elite #709
rcole927@earthlink.net
Roger Cole
Post by Roger Cole » Sun Feb 19, 2012 5:54 pm
Hi Nig,
Yes, I am still on the same telephone number that I have been using
for the past 35 years.
I hope you are having a merry Christmas.
-----Roger
On Dec 24, 2009, at 11:43 AM, N.Smith wrote:
Hi Roger
you
Nig 745E
Of Roger
Cole
To: Rebel Builders
(CC-35)?
Roger Cole
Murphy Elite #709
