[rebel-builders] Fus 30 Doubler
Post by Ken » Sun Feb 19, 2012 5:50 pm
I agree that it probably does not matter much Geoff but I'd also guess
that it will be quite difficult to actually do it that way especially if
any rivet holes are already drilled. I would not be brave enough to
attempt it. Either way the part is hidden under the stab anyway and
there will be lots more rivets for doublers around the elevator push
tubes and rudder cables. It is a tricky area and I recall upping a few
of the rivets to 5/32 when some #30 holes ended up a bit oval.
Aesthetically it is a non issue to me.
Geoff van Asch wrote:
G'day
I am doing the FUS 30 and stuffed up the attach to the bulkhead Fus 36.
With much #%&@& and the part now replaced - (fits far better the
second time so I have got over the issue of stuffing up.)
But the question.
I have the back half of the stuffed FUS 30 (remember my issue was the
front) so I will use that as the doubler.
Is there any reason that the FUS 30 doubler at the construction stage
can't be placed inside the full FUS 30?
The end product would look at whole lot cleaner and to me whether the
doubler is on the inside or outside where it attaches to the Fin
shouldn't matter.
Anyone with any thoughts
Thanks in advance.
Geoff van Asch
Rebel 798
Jeff Micheal
Post by Jeff Micheal » Sun Feb 19, 2012 5:50 pm
Geoff,
I'm building a Rebel and installed the doubler on the underside of the
horizontal bulkhead. Also increased the length of the doubler so it meets
the vertical bulkhead for the tail spring forward anchor bolt.
I can send you a pic the next time I'm at the hanger if you like.
Jeff
On Thu, Dec 17, 2009 at 6:00 PM, Geoff van Asch <Geoff@tva.co.nz> wrote:
G'day
But the question.
shouldn't matter.
Thanks in advance.
Geoff van Asch
Rebel 798
52 Scott Street
P O Box 1003, Blenheim 7240, New Zealand
ph 03 578-3386
fax 03 578-3448
<http://www.tva.co.nz/>
The information contained in this message is CONFIDENTIAL INFORMATION,
and may also be LEGALLY PRIVILEGED, included only for the individual or
entity names above. If you are not the intended recipient, you are
hereby notified that any use, review, dissemination, distribution or
copying of this document is strictly prohibited. If you have received
this document in error, please immediately notify us by telephone (call
collect the number above) and destroy the original message.
The Halls
Post by The Halls » Sun Feb 19, 2012 5:50 pm
To: <rebel-builders-d@dcsol.com>
Sent: Thursday, December 17, 2009 9:00 PM
Subject: [rebel-builders] Fus 30 Doubler
G'day
But the question.
shouldn't matter.
Thanks in advance.
Geoff van Asch
Rebel 798
52 Scott Street
ph 03 578-3386
fax 03 578-3448
Roland Kriening
Post by Roland Kriening » Sun Feb 19, 2012 5:50 pm
Hey Jeff,
Could you post the pic on the site. I too am interested in how and where the
doubler should be fit.
Roland
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Jeff
Micheal
Sent: Friday, December 18, 2009 2:52 AM
Subject: Re: [rebel-builders] Fus 30 Doubler
Geoff,
Jeff
G'day
But the question.
shouldn't matter.
Thanks in advance.
Geoff van Asch
Rebel 798
52 Scott Street
ph 03 578-3386
fax 03 578-3448
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 5:50 pm
Roland,
There's a pic of my FUS-30 installation at http://n254mr.com/node/61, which
shows a commonly used layout. Click on the thumbnail there to expand the
actual photo. (The rivets around the elevator tube holes weren't done yet,
of course.) There's a lot more about that job on the web site if you search
for "FUS-30". There's also lots of info about this task in the list message
archives on the builders web site -- using the same search term.
That was an early job for me, not long after I got the partially completed
project, and before I had a clue about metal work. So although the concept
is reasonably good, the workmanship isn't exactly pristine. :-( Now I have
a clue (it's around here somewhere) but still haven't been able to solve any
puzzles. ;-)
Ron
254R
http://n254mr.com
On Fri, Dec 18, 2009 at 4:31 AM, Roland Kriening <kriening@rogers.com>wrote:
Hey Jeff,
Roland
Micheal
Geoff,
Jeff
G'day
But the question.
shouldn't matter.
Thanks in advance.
Geoff van Asch
Rebel 798
52 Scott Street
ph 03 578-3386
fax 03 578-3448
